Speaker Question
kwman8
Speaker Question
Post by kwman8 »
I found a set of subs in a custom box outside. I picked them up and want to install them in my 04 Vibe with Moon and Tunes package with the stock head unit. Do I have to buy an amp or can it work with the m&T amp? What would be the easiest place to wire it into.
damronjr
Re: Speaker Question (kwman8)
Post by damronjr »
You could probably branch off of one of your speaker wires, but I wouldn't recommend it, it wouldn't sound very good, and it might even ruin your amp or sub(s). Best bet is to get a new amp and a scosche line converter. That would be the cheapest route for the best possible sound without getting a new head unit and amp(s).
kwman8
Re: Speaker Question (damronjr)
Post by kwman8 »
Thanks. Do you have any recomendations for a cheap amp?
damronjr
Post by damronjr »
Quote, originally posted by kwman8 »Thanks. Do you have any recomendations for a cheap amp?The only places I can think of that might carry that kind of stuff would be like Walmart, Circuit City, or Best Buy. Ebay is a possibility, but kind of risky.
Jahntassa
Post by Jahntassa »
Depends on the subs. We'd need to know what subs they are. See if there's text on the front, else you'll have to take one out and see what it is. And no, you can't run it off the M&T amp.
kwman8
Post by kwman8 »
They are 2 Roadmaster RTS3200 6-1/2” woofers. I believe they are only 300 watts. Will it still be necessary to buy an amp?
There's no way you won't have to buy an amp. The factory amp is designed to power what's already in the car, nothing more.
Jahntassa
Post by Jahntassa »
Any small amplifier will do. You probably don't want to get anything really bigger than 50w or 60w x2. 6 1/2's aren't really meant for power, and if you 'found it', they may already be blown...
Raivis
Post by Raivis »
also if your hooking up to a stock stereo you need to buy a piece for the back to hook up RCA's i forget what its called its like an RF modulator they run about $20 at any stereo shop
You got owned by a wagon..... Life is a sexually transmitted disease!!! check me out at http://www.myspace.com/raiviskysdad
damronjr
Re: (Raivis)
Post by damronjr »
Yeah, that's the scosche line converter I was talking about. Like $17 at Walmart.
