What is the correct pressure for stock tires?
victorzhu
Post by victorzhu »
And when should I measure the pressure? Thanks.
tnpartsguy
Post by tnpartsguy »
32 lbs. And it should be measured cold; ie 1st thing in the AM or at least 3 hours since the car was driven.
victorzhu
Post by victorzhu »
Thanks, so I did complete wrong, I usually measure the pressure after driving. :-(
utahindie
Re: (victorzhu)
Post by utahindie »
add 3 psi if warm
Merzbow
Re: (utahindie)
Post by Merzbow »
I keep mine at 31
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
zionzr2
Post by zionzr2 »
Open driver door and look in the door well to your right....There is a label detailing tire pressure and weight limits for the vehicle.Mine it says 35lbs in front and 32 lbs in the rear though i have a AWD
mcgusto82
Re: What is the correct pressure for stock tires? (silverawd26)
Post by mcgusto82 »
a litle bit higher would probably get an improvement on gas mileage. mine arre set at 35. i drive 21 miles each way to work 6 days a week. my gas goes for 8 days @ 33mpg for the week.
drunkenmaxx
Re: What is the correct pressure for stock tires? (mcgusto82)
Post by drunkenmaxx »
i rock em 32 front 35 rear
MrCritical
Re: (utahindie)
Post by MrCritical »
Correct tire pressures on driver's door or body where door and body meet. White laminated card.
