What percentage of base models are manual transmission?
esjones
Post by esjones »
Does anyone here know what percentage of base Vibes are equipped with manual transmissions vs. automatic?
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
goodvibe
Re: What percentage of base models are manual transmission? (esjones)
Post by goodvibe »
I would guess that an upper 80% are autos but a lower auto % here.
esjones
Re: What percentage of base models are manual transmission? (goodvibe)
Post by esjones »
Quote, originally posted by goodvibe »I would guess that an upper 80% are autos but a lower auto % here.Thanks for the guess, but I was wondering if someone had reports from NUMMI or Pontiac that might have the true numbers.
goodvibe
Post by goodvibe »
Your welcome, I did try to find it but couldn't. This was the best I could do. http://www.genvibe.com/html/news/headlines.shtml This is a great site. Most dealer lots won't have a base manual and many will get the GT. I know that was the case when I was looking at the largest Chicagoland dealer. I'm also curious about the real #s but I doubt would wager that Vibe stick purchase is in the low to mid teens.
sylvainber
Post by sylvainber »
my dealer keeps one base manual only on his lot. the other local dealers seem to follow the same trend. roughly, that's one out of 10-15 vibes locally that are stick.
Salsa 2-tone Basecargo nets, liner and seatback storageThe best thing about having my previous car totaled in an accident is that i got a Vibe to replace it
Thewhite
Post by Thewhite »
I don't know why you need that info, but I think you'll have better result if you ask directly to Pontiac via their website and customer service...
'03 Vibe StandardFast Wheel Talon 17x7 Toyo Proxes T1-S 225/45Magnaflow Cat backDevelop's Strut Tower Brace
esjones
Re: (Thewhite)
Post by esjones »
Quote, originally posted by Thewhite »I don't know why you need that info...Because I am CURIOUS. I must have missed the note that said this was a need-to-know only forum.
RIT
Re: (esjones)
Post by RIT »
Not a direct answer to your question, but my dealer has probably 30 Vibes on his lot, and they are ALL Base/Automatics. Seems like the manual transmission is a dying breed, even though both my Maxima and Vibe are sticks. I even had a stick Caravan, before it died!
esjones
Re: (RIT)
Post by esjones »
Quote, originally posted by RIT »Not a direct answer to your question, but my dealer has probably 30 Vibes on his lot, and they are ALL Base/Automatics. Seems like the manual transmission is a dying breed.I have pretty much the same feeling. You used to see even the big Chevy Impala available with a manual back into the early 60's. Now, manual transmissions are largely found only in sports cars, econoboxes or enthusiast cars. I would put the Vibe in that last category because it generates so much enthusiasm among its drivers!
goodvibe
Re: (esjones)
Post by goodvibe »
So you can have feelings and I can't have a guess huh!
