You can use sythetic the day you bring the car home. The very first day my wife and I bought our 2001 Kia Spectra (Not a very good car) I changed the trany fluid and oil out to Amsoil oil. Never had a problem. Since then it's only had one oil change because I'm doing the extended 25,000 mile oil change interval.GM's Corvette has been factory-filled with synthetic engine oil since 1992; the Dodge Viper since 1997! VW TDI diesels are serviced with synthetic engine oil as part of their warranty program.All Porsches come factory filled with synthetic.Briggs and Stratton recommends synthetic 5W- or 10W-30 for all temperature use . B&S cautions that air cooled engines run hotter than automotive engines and using non-synthetic multi-viscosity oils above 40°F (4°C) will result in higher than normal oil consumption.Synthetics are used in every military, and commercial jet, all of the Space Shuttles, and every satellite in space, because of their ability to withstand the extreme heat, extreme cold and high pressures encountered in those hostile environments. WHY does every Jet Fighter Engine in The World use SYNTHETIC LUbricants Exclusively? Because it's the best.How about the Air Force publication Driver in April 1978 and reprint in August 1979 of which showed a synthetic-lubricated Chevy 454 block after 70,000-miles - The factory cylinder honing marks were still present, and virtaully sludge free oil gallery.In the September 1999 issue of Corvette Fever they gained several free horsepower by just switching to this avanced (35,000-mile / 12-month EXTENDED DRAIN) 0w-30 Synthetic Oil technology technology... alot of racers use it - they poor out their sponsors oil product out and put this in their sponsors container... this technology has been deliveing up to as much as a 40% increase in passenger veicle fuel economy since 1995.
http://forums.genvibe.com/zerothread?id=2354Also up to 60% of all engine wear is done by contaminants in the 5-20 micron range. Amsoil oil filters are designed with the extended mile oil change in mind and trap particles this size for even longer engine life. Just using a great oil isn't enough. You must use a oil filter designed for high mileage and small particle filtration.
