Line Output Converters
bh357
Post by bh357 »
I need to hook up an amp to the factory radio (6 disk no M&T). Would this adapter work? http://www.cardomain.com/item/SCOFAI3 Also, does anyone have the connecter diagram or wiring chart for the factory radio? The only one I found is the one for the M&T package. I would like to splice the line level converter in behind the radio. Lastly, does the factory radio provide any sort of switched 12v line, that comes on when the radio is turned on?Thanks.
theangrydwarf1
Re: Line Output Converters (bh357)
Post by theangrydwarf1 »
Should work just fine. I don't see why it wouldn't.
"Do not worry about your difficulties in Mathematics. I can assure you mine are still greater." AE"Science without religion is lame. Religion without science is blind." AE"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." AE
GMJAP
Post by GMJAP »
Schematic for factory radio. The Antenna Amplifier supply output might give you 12v switched with the radio, but I'm not sure. You'll have to check.
GMJAP
Re: Line Output Converters (GMJAP)
Post by GMJAP »
24-pin radio connector diagram attached:
