I had a Cosmo CAI on order but it kept getting delayed so I cancelled that order and got one off Ebay for $55.00 shipped. It is a two-piece intake in chrome polish. It took about 2 hours to install (about 4 times longer that the Cosmo Short Ram I had.) I had to loosen the fuse box bolts and the headlight bolts to get it in. I also had to relocate the Hyper Voltage system box. I can definitely notice a difference between the CAI and the SR that I had in there. I would definitely recommend a CAI over a SR to anyone thinking about getting one of them. The CAI has a little higher pitch sound than the SR I had. I may try to deaden the sound just a little just to get it to a lower pitch. The battery was disconnected throughout the whole install. I let it run for 15 so the MAF and ECU could adjust to the new air flow. I turned it off for about 2-3 minutes then started it up again and went for a test drive. Typically, if there is going to be a CEL it will happen after starting and stopping the engine 3-4 times. So I cycled the engine 4 times and have not as of yet received a CEL. The second chance to receive a CEL will be between 200 & 400 miles after the install. Hopefully, all will be good.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
What differences (if any) are you seeing between the CAI and Short Ram? Other than the install time. 2 hours is about what it took me to install my Injen CAI, it is a little awkward getting it to fit in that small area where it is supposed to go. But it is all worth it for the sound and HP gain.
From what I can tell, it is definitely worth going with the CAI over the SR. I am noticing that starting off the line is about the same as the SR but more power as the RPMs increase with the CAI. The sound is a little different from the SR. It sounds a little more distant but a little higher pitched. I like the sound better with the CAI. I think the pitch is a little higher with the CAI because the CAI is 2.5" diameter and the SR was 3" diameter.
My Fleet:
Wow! After driving it around for a while, the sound of hte CAI has mellowed out enouhg so it sounds perfect now. The MAF and ECU must have still been adjusting to the optimum A/F ratio. Also, I have noticed the acceleration is much smoother now with the CAI vs SR. I love it! Why didn't I do this sooner? I know why, the more mods I do the more experience and confidence I gain with being able to do the mods myself. It is pretty sweet!
My Fleet:
