speaker help
satur9
speaker help
Post by satur9 »
my driver side sony door speaker sound drops out sometimes like if i hit a bump or sometimes it drops and comes back on when i hit a bump.sometimes it does it all on its own. the wierd thing is if i press the cone it immediately comes back on.my wiring to the speaker is nice and tight,and i thought perhaps one of the wires (2 little strands on back of cone) from the voice coil to the woofer cone had broke. but it looks intact.as does the surround and cone. is this correctable or do i need new speakers.
Jahntassa
Post by Jahntassa »
Factory or aftermarket? It definitely sounds like one of the tinsel leads is bad, probably part that attatches directly to the voicecoil.I'd say replacement is the best way to go..
pissedoffgokart
Re: speaker help (satur9)
Post by pissedoffgokart »
Thinking you have separated the VC from it's housing. I have seen it happen that way before. Press on the cone and it plays, gently lift the cone (move it out) and the VC comes with it!!You'll probably have to replace it, but it was a clean break.
Mr. Poopypants
Re: (Jahntassa)
Post by Mr. Poopypants »
Quote, originally posted by Jahntassa »Factory or aftermarket? It definitely sounds like one of the tinsel leads is bad, probably part that attatches directly to the voicecoil.I'd say replacement is the best way to go..You beat me to it. I had the same problem with one of my old subs in my last car. Really nice Kicker Comp 12" and that lead went bad, replacement was the way to go.
