leaking door seal
tadlag
leaking door seal
Post by tadlag »
I just bought a used 2004 vibe for my wife that has a rear door seal that leaks. the car has 31000 miles on it. can anyone tell me if this is a warranty issue or not?thanks,tadlag
Baltovibe
Re: leaking door seal (tadlag)
Post by Baltovibe »
If you look at this thread, it appears the door seal is covered under warranty. Maybe the door needs adjustment?http://forums.genvibe.com/zerothread?id=7907
it should be under warranty, unless there is some evidence of abuse, and the factory warranty is supposed to transfer with the car, not stay with the original owner.what is it leaking, air or water?
tadlag
Post by tadlag »
water, it just streams in at the top rear curve of the door. i looked at the seal and it looks good.
1badvibe
Post by 1badvibe »
what i am about to tell you is top secret, ancient bodyman secret, shhhhhhhhhhh,put your window down, place your knee on the top of your inside door panel, grab upper part of your door and pull gently. this should elimate your leaks, if not repeat as needed, KEY STEP: roll window down!!
2004 FOR SALE jgtmcn@msn.com
scherry2
Re: leaking door seal (1badvibe)
Post by scherry2 »
Quote, originally posted by 1badvibe »what i am about to tell you is top secret, ancient bodyman secret, shhhhhhhhhhh,put your window down, place your knee on the top of your inside door panel, grab upper part of your door and pull gently. this should elimate your leaks, if not repeat as needed, KEY STEP: roll window down!! do you work in a auto factory? thats how we fix them at work.
1badvibe
Re: leaking door seal (scherry2)
Post by 1badvibe »
body shop
