Stock Amp
BlackGTNJ
Stock Amp
Post by BlackGTNJ »
Does anyone with the stock amp have the speaker wiring diagram. I want to make sure I have all the positives and negatives correct?
Abyss GT - Monotone Paint, Moons and Tunes, Power PackageSilverStar LightsJLAudio XR650 front and RearAlpine CDA-7894Infinity BassLink
NovaResource
Re: Stock Amp (BlackGTNJ)
Post by NovaResource »
I have the service manual and can let you know later.
pissedoffgokart
Post by pissedoffgokart »
I posted this a while back, no has said it is wrrong yet!http://forums.genvibe.com/zerothread?id=1042
ourvibe
Re: Stock Amp 6 disc changer
Post by ourvibe »
Just new to this forum. Actually first forum I've been involved in. So hope I am asking questions OK.I have the factory 6 disc changer with 200 watt amp. Want to replace amp with 4 channel Alpine. Can anyone tell me if the output from the head unit is low or high level. (any idea on voltage level) Is there a wiring diagram that shows the head unit output/amp input. Thanks for help.
2003 Vibe AWD AutoMonotone Satellite
pissedoffgokart
Re: Stock Amp 6 disc changer (ourvibe)
It's all line level my friend! Just plain ol' speaker leads.
ourvibe
Re: Stock Amp (NovaResource)
Post by ourvibe »
Anyway I could talk you into sending me a copy of wiring diagram for the two connectors that go into the 200 watt amp.It would help me out a whole bunch in replacing that piece of CR--Thanksquote:I have the service manual and can let you know later.
shadow
Re: Stock Amp (ourvibe)
Post by shadow »
I'd also love to have a copy of this diagram. I'd like to tap into the rear line leads at the stock amp and wire them to my Kenwood so I can push my Infinity Kappas. I'd be willing to host the picture on my web server!
rockinvibe
Re: Stock Amp (shadow)
Post by rockinvibe »
did you ever receive the wiring diagram for the stock amp. i am adding a sub, and would love to tap into the amp for a lead. please let me know @ stevetietjen@wideopenwest.com. Thanks, Steve
ourvibe
Re: Stock Amp (rockinvibe)
Post by ourvibe »
Never did get a copy of wiring diagram. I did figure it out myself.Everything seems to work OK and polarity checked out with voltage meter.NO GUARANTEES yours will be the same. In our car the wires to speakers change colour somewhere between amp and speaker. Maybe change from GM wiring harness to Toyoto. You should go right from speaker to amp and buzz out wires to confirm correct wires and polarity.What kind of sub do you plan to install.
Attached files radioconnectors.pdf (37.8 KB)
Sub-Vibe-R
Post by Sub-Vibe-R »
Usualy, to make the difference between + and - on wiring, the neg. has the same color as the +, but with a black line.
