A Dumb ?
AzFusionGT
A Dumb ?
Post by AzFusionGT »
Last night, my Dad and I made a Wendy's run. All went well until we got home. Long story short, the stupid cup-holder thingy they gave us, broke. Lemonade spilled all over the passenger seat. My dumb question: If it soaked down far enough, could the lemonade have hurt the sensor for the "stewardess light?" I soaked up what I could with an old shop towel, but it was still pretty wet. I put my backpack there this morning, and the light blinked at me, so I'm guessing no. Any thoughts??
2006 Saturn Vue Red Line -A Moose is on the Loose-1990 Toyota Camry LE-V6 - Katy the Camry -
Raven
Re: A Dumb ? (AzFusionGT)
Post by Raven »
You can only hope, that light is annoying.
Sputnik
Re: A Dumb ? (Sunny)
Post by Sputnik »
Its only annoying if you don't wear a seatbelt. I've never had anything heavy enough other than a person to set it off.
GenVibe Global Moderator
Re: A Dumb ?
I usually carry a laptop bag on the passenger seat, and it always sets off the passenger seat belt light. I just disconnected the light, since I am the only one who drives the car, and when i'm driving the car won't move until everyone is belted in. if putting weight on the seat made the light come on, and removing the weight makes the light go off, then it sounds like it's working ok. did the lemonade stain the seat much?
AzFusionGT
Re: A Dumb ? (joatmon)
It doesn't look too bad. I took a wet towel with Dial soap on it and scrubbed. So far so good.
redlava
Post by redlava »
Lemonade might not show up unless you are in bright sunlight. Grease stains on the other hand are VERY noticable.And I had a bag of groceries on the front seat and the light would flash on and off in a weird sequence because the groceries were bouncing up and down and rocking back and fourth. That was even more noticable than when it just flashes, I can usually tune that out pretty well.
The electrical for the sensor is on the bottom of the seat. It would take a LOT to soak down that far...I'm pretty sure you're fine...might not hurt to get some steam cleaning done down the road at some point!
Re: (ragingfish)
Definitely a long way to go before the liquid hits it. I'm not sure what type of material the sensor in our cars is made out of, but... The type of sensors used for passenger air bag suppresion on some GM stuff looks like they wouldn't be hurt too bad by a little spill.http://www.gmtechlink.com/imag...tory7So yeah, I don't see it hurting anything...
MoonDogg
Re: A Dumb ? (Sputnik)
Post by MoonDogg »
My cat set it off.... Quote, originally posted by Sputnik »Its only annoying if you don't wear a seatbelt. I've never had anything heavy enough other than a person to set it off.
2004 Vibe GT Fusion OrangeOptions: M&T, Monotone Paint, 35% TintMods: Kenwood Excelon KDC-X659 HU, Orion CS200.4 amp, Kicker Comp VR 10" sub, Megan Racing STB, Injen CAI, Magnaflow Cat-Back, brass shifter bushing, underbody orange neon's.
Raven
Post by Raven »
Quote, originally posted by AzFusionGT »It doesn't look too bad. I took a wet towel with Dial soap on it and scrubbed. So far so good. Cool, now the seat will never have BO. Maybe it will absorb other smells coming from that end of the anatomy.
AzFusionGT
I can only hope...don't want my car smellin' like a**
coratz
Post by coratz »
interesting--- so just what does that sensor do? if you eat to much at wendys or macdonalds the airbags go at full force due to the supersize combo in your belly? no for real, what are the specs??????? i know there are warning that unless your 12 , your not to be in the front seat. anyone know the answer?
knoxville2013
Post by knoxville2013 »
it detects a person in the passenger seat by their weight and then it causes the "passenger seatbelt" light to start blinking
Jahntassa
Post by Jahntassa »
On some vehicles with 'smart' air bags, it'll also prevent the passenger side airbag from going in an accident if nobody is in the seat.
