Well I finally broke down and ordered a new Magnaflow Cat-Back exhaust from http://www.ptuning.com/(thank you superbowl heh, heh). And I bought 1" spacers for my rear wheels from Damronjr, now i just need some warmer weather and I'll be ready for the Michigan Super Meet III.
Even better. I had to stick with a free-standing electric fireplace in my house and admitedly it's not as cool but it's a high-end unit and really does work well. A 1500 watt heater in a 13x20ft room, it does the trick.
Mmmm, mm, mm... Toasty!Wow! Nice job on the fireplace. Looks great! I tackled such a beast recently as well.The conceptual stage...The frame and box...The finished product...
Ooh. Nice.Actual hardwood or laminate?I just put laminate in my house a couple of weeks ago. Lots of work, but the results were worth it. Heh, did it just in time to decide to sell the place too.
I see it's on concrete and I noticed the adhesive in the pic, so it must be an engineered plank vs. a solid nail down plank. It should turn out to be a great floor as long as their is no moisture issue with the concrete. Bruce is the best brand name and their engineered plank is very stable and durable. Are you doing the install or getting it done? Keep the pics coming.
having it done. its a little more than I can handle.I installed armstrong swiftlock flooring in my kitchen. this is glue down. I had bruce hardwood floor on it but it was worn (30+ years) out and water damaged.
I said i would never put a mod on with twist ties, but I did. thanks to pyro-andrew I got a new (used) 3 peice grille set. and thanks to drunkenvibe for being too cheap, errrr financially unable to purchase them. The full front cover (bra) won't fit anymore, so I hope to get a bug deflector for dad's day.
looking good... all i want is that year front end!!! *sigh*
Those look wonderful. I don't remember seeing them on a red Vibe before.I've never seen your Vibe naked in the front before. Look how shiny and smooth the nose is!!!
Quote, originally posted by Merzbow »I've never seen your Vibe naked in the front before. Look how shiny and smooth the nose is!!!only in the photo. not up close.Quote, originally posted by Merzbow »Those look wonderful. I don't remember seeing them on a red Vibe before.I don't think I've seen one either so I didn't know for sure how it would look. I'll have to do a litte fabricating on the bra. don't know yet.
I hear double -sided sticky tape works for those kinda bras with no strap!
