Cavailer issue need help!
zionzr2
Post by zionzr2 »
I also have a '02 cavalier (wife's car) its an automatic with a console shifter.... the issue is the the light under it is burrned out, so at night you cant see the letters....Is this something i can do my-self? I cant really see how to get under the console to get at whatever bulb i need....any help greatly appreciatedThanks
Re: Cavailer issue need help! (zionzr2)
Wish I still had my 02 sunfire, I could go o ut there and poke and prod and figure it out myself...Sadly, though, I can't! Good luck though!If you do take it in to be changed, I can't see them charging a heck of a lot to screw in a light bulb...But then again, how many GM service techs does it take to screw in a light bulb?The world may never know!
Devlop
Re: Cavailer issue need help! (ragingfish)
Post by Devlop »
I'm sure its just a peanut bulb that needs to be changed. Its been a while since I have taken one of those apart, but I'm sure there are just a couple of bolts inside at the bottom of the console. You'll probably have to take out some sort of pad at the bottom. There should be screws or bolts at the front also, perhaps in the cup holders. I'm not positive though, like I said, its been a while.
Carbman
Post by Carbman »
If worse comes to worse my old 1983 ford T-Bird had that problem and Icould never find the light so I counted shifts from park and just got used to it after that anymore i dont even look at the gears from park one shift reverse, next shift nuetral, next shift drive. Dont know if this will help or not so good luck man.
ToolGuy
Post by ToolGuy »
You will probably have to remove the shifter lever, the part you grab to shift it. And then remove the center console. The screws to remove the console are under round plugs and exposed screws throught the console. I used to write the serv manuls for these cars but it has been a long time...Like this...
zionzr2
Re: Cavailer issue need help! (MiVibe-ToolGuy)
Post by zionzr2 »
Bulb Replaced.... bulb type (P194)Wont know till dark if its fixed for sure....Man thats a tight spot to workin though....had to pop the entire center console only would move a little bit.took about 20 minutes. to find the right tools and to wrestle the console.Chevy said they would glady do it for $60-80... I said NO! 20mins and $3.50 for a bulb.. I did it myself
ToolGuy
Post by ToolGuy »
Cool, good job! Yeah right, one hours dlr labor for a bulb change, get bent!
micheles_bad_vibe
Post by micheles_bad_vibe »
Last edited by micheles_bad_vibe on Wed May 09, 2012 12:41 pm, edited 1 time in total.
