Well, I just finished with my test drive after installing the Cosmo Racing Short Ram Air Intake. It sounds awesome. It was a very easy install except for one missing hose clamp, which I had to make a run up to Checker Auto Parts to get. It took about 45 Minutes total to install without the trip to the parts store. There were no fitment problems whatsoever. I let it idle for about 20 minutes before taking the test drive. No CEL as of yet. Hopefully I will not have one at all. I know that for some it took up to 200-400 miles before getting a CEL. I will keep my fingers crossed. I only had to disconnect the Mass Air Flow Sensor and the vacuum hose from the stock air box and reconnect the to the new intake. It was much simpler than I thought it was going to be.Here is a pick of the completed install:
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Extra what? I am assuming you are talking about one of 2 things. Either the smog pump hose or the front VSV. I did not have either of those hoses to deal with. Just the MAF Sensor and the Vacuum hose attached to the stock air box. I think they got rid of the front VSV on the 2005 Models and I thought I read somewhere on this forum that the smog pump is only on the GT models or maybe it is a regional thing.
My Fleet:
They decrease the resistance thru-out all of the electronic systems in your vehicle. In turn creating more power. I will give you my actual results after I install and test drive my Vibe.
My Fleet:
Quote, originally posted by damronjr »Cool! Thanks! I always wondered what the purpose of these was.I actually noticed much smoother overall performance from my engine after installing my ground wires last year.
I have bought a cosmo short ram intake for a non GT 2004 vibe my question is I would like to install on it a dfferent filter, it is the same style but a little larger 8 inches over all length and 5.25 O.D. will it fit ?Thanks for any help you could give. Mark
I have the filter that came with the Cosmo Short Ram. It is pretty tight in there. It's not touching anything else. There is about 1/2" space all around before it would hit anything. I wouldn't want any less because it does move around a little bit.Oh, yeah and the smog pump is only on the DBW models.
My Fleet:
Thanks for your help.I installed a uni-filter, it is foam oil penetrated filter that will stop 100% of the dirt. Amsoil did not carry the right size filter.I will attach a picture.Thanks again p.s. it still flows the same amount of air
