im experiencing a really stupid problem with my 2003 vibe. i turn off the car and a few hours later the headlites would come on. this would happen at night, and when i get up in the morning my battery is dead , and i have to jump it. i took it to the dealer and they ran a check of the whole car and didnt find anything wrong with it. if anyone knows how to deal with this , please help me out.
Are your daytime running lights on? If they are, there may be a defect in those. And you may want one of the members do it or you can do it yourself.Inder
tonight they came on at 3 am and turned off on their own after and hour or so. i thought it was an electric problem but i was told that nothing was wrong.
It has nothing to do with DRL.I've heard of this happening with some early production models of the Vibe and Matrix...caused by a defective relay in the headlight circuit...Go to the dealer, there should be a TSB on it.The Toyota TSB is EL001-03. I don't know the GM TSB number.
Quote, originally posted by mudinflamez »whats TSB? i'll def. do that. TSB Technical Service Bulletin A bulletin sent out to dealer service departments to address known problems common to a vehicle.
TSB --Technical Service Bulliten - There was a problem that involved either the Headlight Module or the relay..... A few of us members have had that problem.
Relays are all over the place:behind the steering wheel, above the glove box, in the engine.I don't know which of the dozens is impacted by this TSB as I have never seen the bulletin.You're better off just going to the dealer and letting them handle it.
It is the headlight switch AND the relay. Dealer will fix. For a temporary fix, when you shut the car, make sure your headlight switch is off and turn your highbeams on. This will shut off the low beam circuit.
