windshield icing
iswings
windshield icing
Post by iswings »
My wife got into her 05 Vibe this motning and found the INSIDE of the windshield iced over. When she went to lunch the inside was figgy but not iced over. We have never experienced anyhting like this before. What could the problem be?? Any help would be appreciated.BTW temp this morning was about 28F.
Kari
Re: windshield icing (iswings)
Post by Kari »
Mine gathers a large amount condensation on the inside as well, and I can't figure out why. It's annoying, though. It will literally start running down the inside of the windshield, there's so much water. And it tends to gather toward the bottom on mine, I've noticed. It didn't do it the first winter I had the car -- it decided to start it last year, and it did it yesterday too.
GenVibe Global Moderator
steves76
Post by steves76 »
That also happened to me so I make sure the vent is closed and change the direction of the air to the floor . Sounds a little weird but it seems to work for me.
StampedeVibe
Re: windshield icing (steves76)
Post by StampedeVibe »
That's right.... In the winter, the floor mats tend to get soaked (snow on your shoes), and that increases the humidity inside the Vibe. The moisture will then collect on a cold surface (your windsheild), and eventually freeze.As steve said, the best bet is to direct heat to the floor and dry off those floor mats. After you have defrosted your windsheild of course.
AKLGT
Re: windshield icing (StampedeVibe)
Post by AKLGT »
Quote, originally posted by StampedeVibe »That's right.... In the winter, the floor mats tend to get soaked (snow on your shoes), and that increases the humidity inside the Vibe. The moisture will then collect on a cold surface (your windsheild), and eventually freeze.As steve said, the best bet is to direct heat to the floor and dry off those floor mats. After you have defrosted your windsheild of course. mav says, "what he said"
AKLGT1998 Subaru 2.5RS
dolfnchk
Re: windshield icing (trdvibe)
Post by dolfnchk »
Thanks for the info. It snowed here the other day and this is my first winter with my vibe and I noticed running marks and water marks on the inside of my windshield and back window also and couldn't figure out why or how it got there cause it wasn't there the day before. Now I know what to do.
cdFxer
Post by cdFxer »
If it is accompanied by a sweet smell, your heater core might be leaking.
If it's running down from the top of the windshield, under the roof liner, it could possibly be a disconnected moonroof drain...but that wouldn't explain rundown the back window...I don't think water would travel that far without soaking into the liner...
I think this comes up every winter, not sure if there was a real solution, but theresome info in these previous threads(first one was for icing, others were for fogging)http://forums.genvibe.com/zerothread?id ... ad?id=1687
