( Oops! Sunny gets the "Fast Finger" award! Fired off his note while I was still pondering how to spell "irrefutable"! Anyway, yeah, like he says:o AWDs are a special case re lowering because of their fully independent rear suspension. I believe one or more Genvibers have 'dropped' AWDs, but I don't know details re required parts, effect on alignment and axle C.V. joint angles etc.o Sway/roll/anti-sway/anti-roll bars (all the same thing) are transverse torsional springs on the rear and/or front suspension (Vibes have both) which have no effect on two-wheel bumps but twist to reduce body roll during cornering. Enthusiasts add larger ones to reduce body roll at the expense of greater lateral jolts over one-wheel bumps. Their relative size is also adjusted to tune the handling characteristics of the vehicle.0 Strut Tower Braces are intended to reduce flex in the sheet metal 'towers' that locate the upper end of the front spring/strut assembly, to reduce suspension flexing. On the Vibe, because the towers are well attached to the front cowl, flex is non-existent, per my demonstration in this thread:
http://forums.genvibe.com/zerothread?id=6537 , rendering them a strictly cosmetic addition. (Note: Some disagreement exists re this point; not every Gen Vibe member has bowed to the irrefutable logic of my arguments.)
