oil for high mileage engines
I see advertised motor oils for engines with high mileage, but I don't get it. What makes an oil special for high mileage engines, and if that stuff is good for high mileage engines, why isn't it good for low mileage engines too?
ebslopp
Re: oil for high mileage engines (joatmon)
Post by ebslopp »
Here's an interesting article I found while searching for your answer. http://www.canadiandriver.com/...l.htmSounds like the "high mileage" oils contain other ingredients that are supposed to help revive and retain performance from engine seals and gaskets and so on. You probably could use the high mileage oil in a new engine, but it's more expensive than conventional oil. Synthetic oil is more expensive and is probably better for high mileage engines too.
zionzr2
Post by zionzr2 »
If you use a sythetic from day one...You should never need any other oil...Typically the "higher mileage" oils are a Synthetic blend and are better for those ppl who want to "revive" (term used loosely) their engines from years of conventional oil use.
Altus
Re: (zionzr2)
Post by Altus »
I'll echo that sentiment -- synthetic will give you longer life, longer times between changes (**caveat - not TOO long), and better quality lubrication.For learning all you ever wanted to know about oil, filters etc... and even more - check this site out: http://www.bobistheoilguy.com/ and defineately check out their forums: http://theoildrop.server101.com/cgi/ultimatebb.cgi That's where I learned about the evils of Fram oil filters....And boy would I love to be able to afford a nice bypass filtration system!
Stang2Vibe
Re: (Altus)
Post by Stang2Vibe »
Fram oil filters are bad? I always thought that they were supposed to be good. Dammit! I have one that I bought months back now and haven't used yet. It's probably too late now to take it back or the receipt is long lost anyway. Ugh!
