floor mat has a hole in it
LavaMyVibe
Post by LavaMyVibe »
Is it normal for the driver's side floor mat (not the carpet itself but he standard Vibe mat) to wear so quickly? The mat's carpeting is worn down to the rubber right under the gas pedal in an area that's about the size of a quarter. I guess it's caused by the heel of my shoe but I have less than 11,000KM's on the car. Has anyone else experienced this?
Lava Vibe GTwheel lockshome made cargo matbaby seat15 " Pirelly Winter Carving tiresbrass shifter bushing
Re: floor mat has a hole in it (LavaMyVibe)
This has happened in every car I've ever owned. I switchd to the rubber floor mats, though, and they hold up to just about anything.
Sputnik
Post by Sputnik »
I've never had this problem, but then I really don't drive very much since I walk most places.
GenVibe Global Moderator
Unfortunately, that's pretty common, had it happen to me on other cars. The carpet on the floor mat does wear off over time... My mats are ok for the time being, but then again I've had floor mats on top of the original floor mats from the beginning.
Jahntassa
Post by Jahntassa »
It's a result of toe/heel driving. I've seen some metal plates that go right where your heel goes to protect the carpet. I've seen them at random auto parts stores, but can never find them when i'm looking.I've already worn through the stock floormat..
Raven
Post by Raven »
Does someone drive in high heels? If the hole is the size of a quarter, that could be the cause.
