Constant Noise From Speakers "shhhhh"
platinum_
Post by platinum_ »
when i am listening to the radio, cd, or even the fm modulator, i always hear a constant "shhhhhhh" coming out of the speakers, it is very noticable when songs are changing and tehres that 2 seconds of nothing. When a song starts its still there but is less noticable when it is turned up, during non percussion vocals it is also very easy to notice. Anyone have any idea why its doing this and what to do about it ? --> my guesse is that the stupid amp is trying to amplify nothing and therefor sending noise to the speakers. Any ideas or solutions will help, thx.
Savageone79
Re: Constant Noise From Speakers "shhhhh" (platinum_)
Post by Savageone79 »
Did you get the moons and toons package with the amp? If so you might be getting an over amplification? Are you using the stock head unit or did you put in a new one?
nismo
Post by nismo »
Do you have an amp running through your car?Inder
platinum_
Post by platinum_ »
i have the M&T amp, it is the one i was reffering to in my post, and i do still have the stock 1cd unit. thx.
scherry2
Re: (platinum_)
Post by scherry2 »
Quote, originally posted by platinum_ »i have the M&T amp, it is the one i was reffering to in my post, and i do still have the stock 1cd unit. thx.FM modulator, is this an add on? if so that would be the first place i'd look
platinum_
Post by platinum_ »
yes, but it does this when playing cd's as well, i can understand the fm modulator doing this, but i cant figure out why it does it with cd's.
Re: (platinum_)
there were a couple of threads about white noise when the head unit was turned off, maybe that's related, maybe not. I never noticed the problem in my car.http://forums.genvibe.com/zerothread?id ... ad?id=1817
platinum_
Post by platinum_ »
thanks for the links, i read through them and it seems there are a few people like me that constantly hear the noise, and then those that only hear it when the car is turned off. unfourtunatly there was nothing in there that could help , though i do believe that changing the head unit may help. if not, then getting rid of the M&T amp will for sure. any audio experts please please help. thx.
I always had that problem, I have M&T and single disc.It's gotta be in the amp....
platinum_
Re: (ragingfish)
Post by platinum_ »
its the amp for sure, i get the same thing when i turn up my computer speakers and theres nothing playing (but they cant be worth over $20), it really isnt something the M&T amp should do, and i have noticed that my home theatre doesnt do it either, but alot of cheaper computer speakers, cheap cd players and etc. will give the noise when there is nothing playing, its just what happens when you try to amplify random noise coming through the wires. i just hope there is some kind of solution, i'll see what happens with a new head unit, if that doesnt do it then a new amp is gonna have to go in, i cant stand the noise.
Re: (platinum_)
i'm running a new HU with the stock amp...and it does still exist...i doubt you'll have any more luck than i did...
nismo
Re: (ragingfish)
Post by nismo »
Someone who really knows his stuff is "theimportscene" and "Jahntassa". They both know their stuff very well. So, if you want to, you can PM em and ask em.Inder
Jahntassa
Post by Jahntassa »
My solution is usually taking the M&T amp out of the equation, and getting some brandy new aftermarket speakers. That way, any problems there may be would be with the newer headunit, and the chances of that newer HU being the culprit are pretty small. But...I don't have the M&T, and nobody nearby to really experiment with it...so i'm at a loss to help the actual issue.
Kari
Re: (Jahntassa)
Post by Kari »
I would think it could be taken in as a warranty issue, too, if you have a really good dealership.
GenVibe Global Moderator
kostby
Post by kostby »
The 'white noise' is a documented (but apparently unsolved) problem with early '03's with the Moon & Tunes package, short of replacing the M&T amp.I assumed they fixed it in later model years, because I haven't seen it reported lately, but maybe not. What year is your Vibe?The problem is most apparent immediately for 20 seconds or so after the engine is turned off, (because nothing else is making noise) but, it's ALWAYS there, just covered up by road noise and/or music most of the time. If you have high frequency hearing loss, you'll probably never notice it!Someone has suggested that using (better) shielded cables between the HU and the amp and (better) shielded speaker cables MIGHT help the problem, but basically, it seems to be the M&T amp generating the white noise in the first place.
Kari
Re: Constant Noise From Speakers "shhhhh" (kostby)
Post by Kari »
Not sure what's classified as "early"...but I have an '03 born in October '02, and I've never had a white noise problem. I do get the thing where it amplifies the "squeak" of changing tracks on a CD, but there's no hiss or anything. If they did fix it with later M&T amps, then I would definitely go with the warranty repair thing, if you're still under warranty. It's not supposed to do that, so see if you can get them to exchange the amp.
platinum_
Post by platinum_ »
mine is a 2003 model, but the sticker says 2002, so i suppose mine would be considered an early model 2003. I honestly would care if it only did it when i turned the car off or at certain times, but it does it constantly, never stops, its very annoying.
scherry2
Re: (platinum_)
Post by scherry2 »
I have a early 03 with m/t and i don't have this problem. did you have the problem before you installed the FM modulator? I ask this because that is what the dealer would ask. just trying to help fix the problem, and that is go back to square one.
platinum_
Post by platinum_ »
its always been there, and i dont think i will even waste my time with the dealer.
scherry2
Re: (platinum_)
Post by scherry2 »
"shrugs" I've never had a problem with the dealer (electronically anyway) my CD player scrapped the CD's whenever i put on the brakes, the exchanged it no problem.
