How can you tell the AWD is working?
cds22
Post by cds22 »
This might seem like a dumb question...but... I have an AWD Vibe and had to drive it on snow & ice for the first time a couple of days ago. There doesn't appear to be any light on the dash that indicates when the AWD engages so how do I know if it's working? I know... if my wheels are spinning it's obviously not working! But, what if it's only a bit icy and I'm not noticing any spinning? That doesn't necessarily mean the AWD is working. I've driven other AWD vehicles and they have all had a dash light indicating when it was engaged. Any thoughts?
Carol2003 Vibe AWD, 2-tone Salsa, sunroof, 6 pack CD, security system
Vibe Rater
Re: How can you tell the AWD is working? (cds22)
Post by Vibe Rater »
Maybe the VIBE is full time AWD? Always on?
cds22
Re: How can you tell the AWD is working? (Vibe Rater)
Post by cds22 »
Nope, it's supposed to just engage when it senses that the front wheels are slipping. At least that's my limited understanding (you might have guessed that I'm not very mechanically inclined .
Sub-Vibe-R
Post by Sub-Vibe-R »
Vibe TI is an integral traction (AWD)and not an 4WD. This mean 100% of the power is routed to the front wheel drive in normal driving and when front wheels stars spinning, a % of the power is routed to the rear wheel. When the front wheels stop spinning, 100% of the power goes back to the front. AWD Vibe does not use a transfert case as regular 4x4 but use a limited-slip differential to route power to the wheel with the better traction. Most of the time, you're driving a front wheel drive.
cds22
Re: How can you tell the AWD is working? (Sub-Vibe-R)
Post by cds22 »
Thanks for the clarification! Do you know how to tell if it's working properly or not though?
mu_ohio
Post by mu_ohio »
quote:Thanks for the clarification! Do you know how to tell if it's working properly or not though?If your front tires start to slip, you should feel the rears starting to bite as if it was RWD. I'm not sure what the maximum transfer is, but typically it can as much as 80%.
2004 Pontiac GTOPhantom Black w/black leather
NSimkins
Global Moderator
Post by NSimkins »
quote:Do you know how to tell if it's working properly or not though?Page 4-9 of the Vibe Manual (online version: here) states:"If the front drive wheels begin to slip, the rear wheels will automatically begin to drive the vehicle as required. There may be a slight engagement noise during hard use but this is normal."
d_m_kolb
Re: How can you tell the AWD is working? (mu_ohio)
Post by d_m_kolb »
I max transfer of power to the rear is 50%. I'm sorry I don't know how to tell it's working though.
mu_ohio
Re: How can you tell the AWD is working? (Admin II)
Post by mu_ohio »
You can tell because your front tires won't be spinning wilding while the back ones stand still. I would think in the AWD, it would be near impossible to spin the tires.
