black motor mounts
satur9
black motor mounts
Post by satur9 »
suspension restorations. http://www.suspension.com has energy suspension motor ounts in graphite impregnated black color. for 25 bucks(they boast the cheapest prices) with 2 day air for 12 bucks. they will be 37 bucks.i get thm wednesday.
FusionVGT
Re: black motor mounts (satur9)
Post by FusionVGT »
This is where I got mine. Great place to do business with.
Mr. Poopypants
Post by Mr. Poopypants »
Quote, originally posted by satur9 »suspension restorations. http://www.suspension.com has energy suspension motor ounts in graphite impregnated black color. for 25 bucks(they boast the cheapest prices) with 2 day air for 12 bucks. they will be 37 bucks.i get thm wednesday. OK, I am going to sound a bit dumb here, what exactly do aftermarket motor mounts do for a car?
wicked1981
Re: black motor mounts (Mr. Poopypants)
Post by wicked1981 »
FusionVGT
Post by FusionVGT »
Quote, originally posted by Mr. Poopypants »OK, I am going to sound a bit dumb here, what exactly do aftermarket motor mounts do for a car?There are no dumb questions. The mounts are made of polyurethane and stiffer then the rubber mounts already on the car. If you were to look at factory mounts, you would notice voids in the rubber. These aftermarket mounts work with the factory mounts and fill the voids. The engine doesn't rock back and forth nearly as much as it does now. This helps to nearly eliminate wheelhop, as well as makes shifting easier.
Raven
Post by Raven »
Quote, originally posted by satur9 »suspension restorations. http://www.suspension.com has energy suspension motor ounts in graphite impregnated black color. for 25 bucks(they boast the cheapest prices) with 2 day air for 12 bucks. they will be 37 bucks.i get thm wednesday. http://neverenuf.com/index.cfm...id=74 $22.00
AKLGT
Re: black motor mounts (Sunny)
Post by AKLGT »
are they easy to install yourself? or would you have to take it to a shop?
AKLGT1998 Subaru 2.5RS
FusionVGT
Re: black motor mounts (trdvibe)
Post by FusionVGT »
Quote, originally posted by trdvibe »are they easy to install yourself? or would you have to take it to a shop?I think they're easy. If I've got time next weekend, a friend and I are going to install Hotchkiss sway bars and the engine mounts.
Mr. Poopypants
Re: black motor mounts (FusionVGT)
AHHHH gotcha
