project matrix Turbo on a 2zz-ge
blk182@n7
Post by blk182@n7 »
this is a really good article...XS put a turbo on a 2zz-gehttp://www.sportcompactcarweb....atrix/
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
Evanshall
Post by Evanshall »
the HP numbers arnt bad at all, although id defenetly lean towards the stratford turbo cuz its 2k cheaper and usitlizes a bigger turbo,one thing odd about that artical was the 1/4mile times, they simply sucked, Motortrend im pretty sure ran 15.7 stock, thats almost a full second quicker then sport compacts run?? wonder what would happen if motor trend drove the turbos XRS
Smokin' Rubber
Re: (Evanshall)
Post by Smokin' Rubber »
Yeah pretty nice they got 241 whp on the Celica the kit was original meant for.I'm thinking that since I'm making so much money this summer I'm going to try to fully deck out my car. Meaning...-8.8:1 compression piston heads-forged rods-reinforced cylinder sleeves-turbo kit (hopefully running as above 10 or 12 psi depends how much the engine can take with the reinforcements)-6 point clutch-lightweight flywheel-limited slip differential-APEXi Power FC-Guages + Pod-Nitrous Injection System-New tranny if neededI'm sure that enough to generate quite a bit of hp then afterwards I'd work on that body kit
Psychobroker
Re: (Smokin' Rubber)
Post by Psychobroker »
Quote, originally posted by Smokin' Rubber »-8.8:1 compression piston heads-forged rods-reinforced cylinder sleeves-turbo kit (hopefully running as above 10 or 12 psi depends how much the engine can take with the reinforcements)-6 point clutch-lightweight flywheel-limited slip differential-APEXi Power FC-Guages + Pod-Nitrous Injection System-New tranny if neededI'm sure that enough to generate quite a bit of hp then afterwards I'd work on that body kit Yikes! Your Vibe will be in the shop more than it's on the road Sounds like an awesome plan!
Smokin' Rubber
Re: (Psychobroker)
Lol yeah cause you know I'm going to be like "35 psi that sounds fun!" and my next post "Uh.... guys... I blew up my engine already." Then it would be in teh shop for a while heheBut I'm probably going to save up so I can get all the engine components and turbo at the same time so I can just take it to the turbo/blower shop near my house and get it all installed at once. The LSD can wait a while, as can the nitrous, and Power FC. I dunno about the tranny tho that would probably need to go if the engine got over 280 hp no idea what kind of tranny I would put in there either. I would hope it would be a 6 speed as wellAnyone know where to get a new tranny that would fit and take the hp/tq beating?
satur9
Post by satur9 »
theyre working on eurospec celica trany gears(theres not realy any swaps) over on http://www.newcelica.org. theyre hoping it will fit us spec housing.well uhmmm... good luck with that 2zz over 13 psi and nitrous thing thats gona be a lot of money and youre gonna break a lot of stuff.this aint no supra here.
Smokin' Rubber
Re: (satur9)
Quote, originally posted by satur9 »good luck with that 2zz over 13 psi and nitrous thing thats gona be a lot of money and youre gonna break a lot of stuff.I know I just said that The engine should be fine tho because of the lowered compression (8.8:1 instead of 11.5:1) and reinforced cylinders, heads, pistons, and rods
