ground wires connections
Smokin' Rubber
Post by Smokin' Rubber »
alright I know where they connect (sort of) but why the heck do they give you a copper disk with a mounting bracket if you don't do anything with them!? So what are you supposed to do then? Connect all the wires to their proper ground but them have all of them attach back to the disk thing?
Smokin' Rubber
Re: ground wires connections (Smokin' Rubber)
Ok the wires are installed but I didn't quite do it like everyone else did with the daisy chain, I actually did a central discharge with 2 runners to the metal of the body/chassis. The mount with the disk sat on top of the negative contact on the battery and all of the wires ran from the disk to somewhere else.For the actual mechanical contacts it ended up being:-left side of manifold-right side of manifold-header (somewhere around there)-transmission (I ended up leaving the stock one on the nearby bolt going to the strut tower as well)-engine blockthen the 2 discharge point were:-below the battery-left side of radiator hanger (the black bracket that holds the radiator)I'll try to post some picture tomorrow My first observations was better low end torque as well as high end punch with smoother revving. The second thing (not sure if this was happening before I put in the wires) was that the idle RPM's went up as stayed around 1400. Bass on the stereo also seems crisper but that could be my imagination.
blk182@n7
Post by blk182@n7 »
here are some pics
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
blk182@n7
Re: ground wires connections (blk182@n7)
Post by blk182@n7 »
connected to the hole on the left side on the 2zz
Stratix
Post by Stratix »
Can ask where you purchased you ground wire kit? I've looked every where!!! At leats 3-4hrs searching on the net. May be I'm looking in the wrong place. Can anyone help?
Smokin' Rubber
Re: ground wires connections (Stratix)
Basically any ground wire kit will work try to find one for a Celica or Corolla or go on ebay
