White plastic cone in air box
kcinmi
Post by kcinmi »
Doesn anyone know why it is there? I would think it would only hinder air getting into the intake.
God, grant me the serenity to accept the things I can not change,the courage to change the things I can, and the wisdom to know the difference.
MadBill
Re: White plastic cone in air box (kcinmi)
Post by MadBill »
I don't know about the GT, but the base Vibe has a white air bell with about a 1/4" mesh grid over it. The bell shape is to improve air flow into the downstream portion of the air box and I think the grid is to reduce turbulence/straighten the flow to give the mass airflow sensor a consistent sample. On other vehicles, removing such grids has been shown to help air flow and power, but there is a risk of screwing up the MAF readings...
kcinmi
Post by kcinmi »
I found it when I put the K&N in and took it off for one tank of gas, and then put it back in. I havent noticed any difference. But any way I can find to make the engine a little more responsive Im willing to try, especially if its free!
MadBill
Re: (kcinmi)
Post by MadBill »
Based on test data I have seen on intake shapes, the bell likely adds about 5% air flow. Since the grid probably reduces the flow about the same or a bit more, removing the whole thing would have no effect except perhaps on the MAF reading. I think you would have to remove the grid but leave the bell. I had planned to price one (if they're sold separately) before I carved out the grid, JIC it didn't work.
NovaResource2
Re: (kcinmi)
Post by NovaResource2 »
Quote, originally posted by kcinmi »I found it when I put the K&N in and took it off for one tank of gas, and then put it back in. I havent noticed any difference. But any way I can find to make the engine a little more responsive Im willing to try, especially if its free!It's been discussed before:http://forums.genvibe.com/zerothread?id ... d=6140It's to smooth the air flow past the MAF. Leave it there.
kcinmi
Post by kcinmi »
Allrighty, I shall leave it in then, Thanks for all your help!
ToolGuy
Re: (kcinmi)
Post by ToolGuy »
Yeap, part of/for the MAF leave it alone.
