2zz Detailed Engine Specs?
a58vette
Post by a58vette »
I am trying to configure the 2zz engine on my dyno software but it does not have the 2zz engine available. I already know the bore, stroke, and compression. But I need to know the camshaft details, wall thickness and other detailed information as such. If you have any information please let me know.
d_m_kolb
Re: 2zz Detailed Engine Specs? (a58vette)
Post by d_m_kolb »
1ZZ-FE info2ZZ-GE infoMMC All Aluminum Cylinder Block (2ZZ-GE)Camshafts and Rocker ArmsLeightweight Valvetrain componentsInfo provided from our friends at MatrixVibe.net
a58vette
Post by a58vette »
Thats what I'm looking for. Thanks
DABEAR95
Post by DABEAR95 »
I have tried switching everything into desktop dyno to simulate the power output, but it is difficult because I don't know the cam timing during lift. I just used the high lift cam numbers so I could look at the output over 6,000 RPM. I have the lift and duration but it still is not correct. I have to play around some more. I was able to model and play with my camaro engine successfully however.Jason
2003 Vibe GT Lava w/accent + 17'' wheels2002 VW Golf TDI 43City/52Highway lifetime1995 Camaro Z28 CAI,!TB,Airfoil,Shorty Headers,!CAT,Borla exhaust, 3.73's w/eaton posi. 13.5@105 with 245/50/16 Michelin XGT's = no traction
MadBill
Re: 2zz Detailed Engine Specs? (Admin II)
Post by MadBill »
Hmm! Re above sites:1. The 1zz engine shown has an aluminum intake manifold, of a very different design than our plastic one. (Looks a lot like an early Oldsmobile Quad Four!)2. The power quoted for the 1zz in the chart on the 2zz engine report is 107 kW, or 143.4 HP....
