Who thinks I should buy these for my Vibe?
Smokin' Rubber
Post by Smokin' Rubber »
"19X9 rear 19X8 front. Offset 42 5/5M PCD 100/114.3 GM with Nitto 245/35ZR19 93W on front and 275/30ZR 96W. (2003). 300 miles on tires." For only $100 lolAnd yeah I know that I have a front wheel drive so it makes no sense to have larger rear tires but oh well. Hehe and now I can be like MadBill and have 270's on my car
ebslopp
Re: Who thinks I should buy these for my Vibe? (Smokin' Rubber)
Post by ebslopp »
I think you should buy those for MY vibe! Those are nice. You'd be a fool not to buy them.
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
nismo
Post by nismo »
WOW! Those are some beautiful wheels. They look like Racing Harts
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
Mr. Poopypants
Post by Mr. Poopypants »
If you don't buy them I will. GIVE ME THE SELLER'S INFO!
Jahntassa
Post by Jahntassa »
Hell, for that price, go for it! I think with 19's you might need to get your speedo recalibrated though...
ebslopp
Re: (Jahntassa)
Post by ebslopp »
Quote, originally posted by Jahntassa »Hell, for that price, go for it! I think with 19's you might need to get your speedo recalibrated though...Is that possible? I didn't think we could calibrate the speedo.
dsegundo
Post by dsegundo »
You'd have to....19's are cutting it a tad close though.
Smokin' Rubber
Re: (dsegundo)
well its not that the 19's in 35 ratio wouldn't fit its the fact that its 19 and its 275 wide lol, altho MadBill managed to fit 275 18's so I think I should be ok
ALi3N
Re: (Smokin' Rubber)
Post by ALi3N »
if you are only talking about wheel diameter it would have no affect on the speedometer reading, what would do it is a different outer tire diameter. Tire width should not have an affect on how the speedo reads either, however that will adversely affect your turning radius.
ALi3N aka Dj ViP3RThere is a force through the euphoric beat causing uncontrolablemovement of your body, I am that force. Take a journey beyond the limits of your mind.'Download Mixes:http://shlrm.org/DjViP3R/http://www.myspace.com/djvip3r Latest Mixes: 'Nightlife' & 'M0Ti0N -X-'Pimpin' Abyss Vibe GT w/ Nav
Smokin' Rubber
Re: (ALi3N)
Quote, originally posted by ALi3N »if you are only talking about wheel diameter it would have no affect on the speedometer reading, what would do it is a different outer tire diameter. Tire width should not have an affect on how the speedo reads either, however that will adversely affect your turning radius.well technically if the diameter of the wheels + tires is larger than whatever the stock is the speedometer will be off (and the offset will be worse at higher speeds) due to the fact that the larger the diameter a wheel/tire is the less it has to rotate to go one mile, this means that your speedometer will be showing a lower speed than what you are actually going.as for adversely effecting turning radius, this is only and issue if the new width rubs up against the wheel well before it actually hits the mechanical barrier that prevents the wheels from turning any farther. Since the front wheels are only 245 in width there should be no problems with the turning.
