3000 RPM or lower
scherry2
3000 RPM or lower
Post by scherry2 »
Well, I just watched a wrecker service haul my vibe to the dealer, I was mounting my neons today and about 4:00 P.M. I was going to run to the store and my check engine light came on when i started it(not flashing). and it was Idling a little high. I put it in drive and around 2000 to 3000 RPM it started to cut out like it was starving for gas, I cleared the code and restarted it and no change. I'll call the dealer tomorrow and find out the problem. I never even got my neons hooked up, just got them mounted.
ragingfish
Re: 3000 RPM or lower (scherry2)
Post by ragingfish »
Weeeeeeird....I'm guessing you don't have a scanner to know what the code was?
2009 PONTIAC G8
scherry2
Re: 3000 RPM or lower (ragingfish)
Post by scherry2 »
no, I wish i did though. good thing its under warranty.
VibeChick
Post by VibeChick »
Sounds exactly like what happened when Phil's MAF sensor went belly up.
Used to have: 04 Monotone Abyss 5 SpeedNow the proud owner of a black 2005 SRT-4230 Hp250 lb/ft torque
scherry2
Re: 3000 RPM or lower (silverawd26)
Post by scherry2 »
Quote, originally posted by silverawd26 »Sheldon, were for poking around the engine bay at all and maybe bumped something?that was the first thing i thought but no, I wasn't near any wires or vacumn lines. I was working on both sides and under the front. I even checked the plugs and vacumn lines by the CAI and i wasn't even near those areas.
Jahntassa
Post by Jahntassa »
Hopefully it's just a sensor thing. You'll get it back soon!
Mavrik
Re: (Jahntassa)
Post by Mavrik »
I'm betting its the MAF sensor, sounds exactly what mine was doing... and if I am correct in this, no one will have a part and will take a few days to get one. I ordered one on friday before the meet and it came in weds of the following week. Never did find out what happened to mine.
scherry2
Re: (Mavrik)
Post by scherry2 »
Quote, originally posted by Mavrik »I'm betting its the MAF sensor, sounds exactly what mine was doing... and if I am correct in this, no one will have a part and will take a few days to get one. I ordered one on friday before the meet and it came in weds of the following week. Never did find out what happened to mine.Thats what it was and the service rep said it probably happend when i installed the CAI. but they covered it under warranty and they had one on hand.
ragingfish
Re: (scherry2)
Quote, originally posted by scherry2 »Thats what it was and the service rep said it probably happend when i installed the CAI. but they covered it under warranty and they had one on hand. Hasn't your intake been in for a while now?
2009 PONTIAC G8
Mavrik
Re: (scherry2)
Post by Mavrik »
Quote, originally posted by scherry2 »Thats what it was and the service rep said it probably happend when i installed the CAI. but they covered it under warranty and they had one on hand. Yeah exactly what I "did" to mine but I bet you can't remember how you "might" have damaged it either huh... wonder why yours took so long to act up though... hah and you took it there with the CAI in right? I ripped mine out to do that as I told ya at the meet.
scherry2
Re: (ragingfish)
Post by scherry2 »
Quote, originally posted by ragingfish »Hasn't your intake been in for a while now?Yea about a year or more ago, I might have damaged it when i did the install. It just took a little longer to go bad.the dealer has known I have the CAI so why hide it.I thought it was quite nice they covered it under warranty even the towing.I hope eveyone enjoyed the guessing game, your pie is in the mail.
Kissfan79
Re: (scherry2)
Post by Kissfan79 »
Anyone know how much a MAF sensor would cost to buy? My warranty is expired (comming up on 41,000 miles ) and was just curious in case I ever had to replace it myself.Jim
Abyss Vibe GT monotoneMoon & Tunes w/6 disc changerCargo nets and mat93 Octane w/ lots o' KISS in the CD changer
Mavrik
Re: (Kissfan79)
Post by Mavrik »
Its over $100 CAD...
AKLGT
Re: (scherry2)
Post by AKLGT »
question: when was the last time you cleaned the filter? i know on my tundra i learned that the filter, if not cleaned well or properly, can send the oil and junk up the intake tube and screw up the maf. i usually clean mine every 15K miles even tho it says you don't have to do it for 25-30K miles. and if it's not cleaned and gets dirt and grime that some particals will pass thru the filter and also mess it up.
AKLGT1998 Subaru 2.5RS
scherry2
Re: (trdvibe)
Post by scherry2 »
I've cleand it 2x and i have 12,000 miles. good idea though.
ragingfish
Re: (Kissfan79)
Quote, originally posted by Kissfan79 »Anyone know how much a MAF sensor would cost to buy? My warranty is expired (comming up on 41,000 miles ) and was just curious in case I ever had to replace it myself.JimList is about $180, GMPD is listing it at $83.
2009 PONTIAC G8
victorzhu
Post by victorzhu »
My new vibe was taken to dealer for repair (at about 256 km). They told me there was a defect sensor(can't remember the name), but seems we got the similar problem. The engine always work at more than 3000 RPM.I leave my vibe at the dealer for 6 days, but they did give me a Chev. Malibu (like new, also have 200km on it), which I found out the have a better control. I guess this is a really weak part for our vibes.
goodvibe
Re: 3000 RPM or lower (victorzhu)
Post by goodvibe »
scherry2, It's best to wait till atleast 20k mi. to clean the filter unless it's real dirty where you are. Gauze fiters don't filter as well as stock(well enough) but do better as they get dirty. You won't see any flow reduction for 20k mi. If your sensor acts up again after a filter cleaning (and sitting out for a day), you can try to clean it with contact cleaner or carb cleaner.
scherry2
Re: 3000 RPM or lower (goodvibe)
Post by scherry2 »
cool! thanks for the tip I've never run a K&N type filter before. ya learn something new every day.
goodvibe
Post by goodvibe »
We all learn the hard way unfortunately. Raises hand. I took a new K&N drop in out off the carton and put it directly into my intake and fouled the MAF in a day. Next oil filter will sit out of its seal to tac for a while before I install. By the way, I bought a spare MAF on ebay for $25 bucks just in case. Came off a low mi. totaled RAV4. My original works fine after I cleaned it but it's nice to have a spare. I'll just use it in my AEM intake when I install.
Cidderiforous
Post by Cidderiforous »
sounds like the problem I'm having right now....4000 rpm and lower ...but I took the car to Autozone and they hooked up the scanner to it, and it said cylinder 1 and 4 misfired... it was raining when the problem started, and I'm thinking I got water in my CAI and that might be causing the misfiring, but I would think that the water should've evaporated by now, and after 4000rpm, it runs right I'm afraid to take it to the dealer though, but I'm getting close to the end of warranty.....28000 miles
Cidderiforous
Cidderiforous
Re: 3000 RPM or lower (Cidderiforous)
well I took it to the dealer. been in and out of the dealership for the past 3 weeks...they can't seem to find the problem.....trouble is...it only happenes when I turn...they hooked up an onboard diagnostic computer and had me drive around for a couple days..of course I couldn't get the damn thing to do it then....anyway....I still wonder if it might be the MAF sensor??
Cidderiforous
