Hatch Door Tie Down
Rivlen
Hatch Door Tie Down
Post by Rivlen »
Hi all;I was just thinking about an idea that I don't know if anyone has mentioned here ... if you have a long item in the back that requires that the hatch remain open, how are people securing the door?I've clipped a bungee to the wiper pivot (probably not the best place to clip to), and to the latch catch on the floor. The thought I had was to suggest to Pontiac to add some sort of tie down point on the hatch (inside of door or even on the bottom of the door would be a good place for it.) If it was inside, it could be another metal ring or something.What are your thoughts?
2004 Pontiac VIBE (base)Monotone FUSION (Sun Burst)Tinted WindowsPower Pkg.Moons & TunesVent VisorsWheel LocksBumper GuardNew *** Sylver s
Jahntassa
Post by Jahntassa »
A place to tie down on the hatch would be a good idea... When I have long stuff (a futon, for example), I actually just opened the glass in the hatch and put it through there, using bungees to hold the futon in.
Kazig
Re: Hatch Door Tie Down (Rivlen)
Post by Kazig »
Quote, originally posted by Rivlen »What are your thoughts? A bungee hook latches right into the trunk lock, just set it up with the hook pointed to the rear and push it into the latch.
KazigBase NeptuneMoon and Tunes, Power Package, 4spd AutoTinted Windows, Real-time OBDII Monitoring.Lapeer, MIOn the keyboard of life keep one finger on the escape key!
Atomb
Post by Atomb »
i always used Kazig's solution on my VW golf...i haven't looked a the Vibe yet but it should be the same....use the trunk lock arm and hook into it facing back (re-stating the last post)
Rivlen
Re: Hatch Door Tie Down (Kazig)
Post by Rivlen »
I'll try that out, I think I had problems with that the first time I looked at it. I guess it just didn't look obvious enough.
SWiRv
Post by SWiRv »
I had the same problem this past weekend when I was hauling 10ft. lengths of wood. I ended up closing the gate and popping open the window hatch with the wood sticking out. I've had 3 hatchbacks in the past, but the Vibe is the first without hooks/loops underneath the lower bumper. But I'll have to try your suggestions. Thanks!
"... to boldly go where no one has gone before." 2004 Pontiac Vibe GTMonotone Salsa3M Hood Protector FilmSylvania SilverstarsInjen Cold Air Intake
