Quick question on wheel upgrade
Bobbyg123
Post by Bobbyg123 »
I'm ordering a Base Vibe in the next day or so, and instead of upgrading to their factory alloy 16" wheels, I think I'll have the car delivered with the stock wheels and upgrade the rims on my own. Will the tires that come from the factory fit any 5 bolt, 5 spoke, 16" wheel? If so, that would be great because I could have winter tires put on the factory steel wheels. Thanks in advance.
ragingfish
Re: Quick question on wheel upgrade (Bobbyg123)
Post by ragingfish »
The tires from the factory are 205 55 R16 tires.They'll fit any rim that can handle 205 55 16 tires. When it comes to wheels, not every 5 bolt, 5 spoke, 16inch wheel is the same. There are different offsets on the bolts, different widths of the wheel (from the spoke face to the rear of the wheel)...There's half a dozen variable.To give you a good idea of what will fit the car, go to http://www.tires.com and put in your car. It will show you all the wheel sizes that fit the car...
2009 PONTIAC G8
goodvibe
Re: Quick question on wheel upgrade (ragingfish)
Post by goodvibe »
Any wheel width from 5.5 to 7.5 but i would look for a 7" wide wheel. They are common, will fit a 225/50 nicely in the future and is not at the extreme end of the current tires fitment.
