Spark intensifiers?
Celtic_Curse
Spark intensifiers?
Post by Celtic_Curse »
Anyone know what the power gains are on those plasma spark intensifiers and what they do exactly. Are tehy mondo expensive?
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
Celtic_Curse
Went to a local shop and they had a MSD spark intensifier, what it does is it jumps the power going to the spark plugs increasing the amount of gas being burnt, a good way to increase HP. Does anyone have one?
AKLGT
Re: (Celtic_Curse)
Post by AKLGT »
hmm. i have no idea what these are. do you have a link for these, ivan?
AKLGT1998 Subaru 2.5RS
HCguy
Re: (trdvibe)
Post by HCguy »
Many tuner cars in SCC have the MSD systems in their cars. Here is the link to the companies website http://www.msdignition.com/
'03 VibeSatelite Grey monotone, base, no mods yet
goodvibe
Re: (HCguy)
Post by goodvibe »
I didn't see anything in that catalog that would boost our spark. I think he's asking about this type of product. http://www.ignitionsolutions.c...t.asp
MJN2
Re: (goodvibe)
Post by MJN2 »
According to that site, the cost of a set for a Vibe GT (Celica GTS listing on the site) is $580.Ouch.
Two-tone Neptune GT w/17" OEM rims, Nav System, BOMZ short ram, Sabresport STB
ebslopp
Re: (MJN2)
Post by ebslopp »
would this be alot different than using sparkplugs with multiple points on them? ex: Bosch Platinum +4I was considering these, but can't justify the cost without knowing for sure that they improve performance.
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
goodvibe
Re: (ebslopp)
Post by goodvibe »
This is the only plug I would consider as an upgrade. I use them. http://www.denso.co.jp/PLUG/iridium-e/ and yes they are different from the ones already in the car. Larger more intense spark.
Celtic_Curse
The system is designed to increase the power of the spark going to the plugs in order to burn more gas in the cylinder thus a cheap way of increasing horsepower, doesn't damage the car but if installed incorrectly will cause damage. The msd unit is what I was shown it sends 470 volts to the plug instead of whatever our basic system does causing way bigger sparks.
goodvibe
Re: (Celtic_Curse)
Post by goodvibe »
We can't use a Capacitive Discharge system like the MSD. Our coils are part of the spark plug connector. One for each plug. The first link I supplied shows this.
cdFxer
Post by cdFxer »
Shorter plug life. With some units MUCH shorter plug life....
goodvibe
Re: (cdFxer)
Post by goodvibe »
Stock Denso iridium 100k+, Denso power iridium 30k. Anything other than platinum or iridium will be less.
