Front windsheild sprayer
renik
Post by renik »
I was just wondering if the front windshelid sprayers are supposed to spray 6 solid streams of fluid on the windsheild. Its like there are 6 powerfull waterguns shooting at the windsheild. A lot of washer fluid comes out but it does not seem to clean the window properly. If this is normal, is there a way to adjust the sprayers to become more like a mist instead?
2004 Base - ShadowAutomaticSafety & SecurityPower PackageAluminum WheelsTinted - 20% front 15% rear
Mavrik
Re: Front windsheild sprayer (silverawd26)
Post by Mavrik »
Either I was tailing my friend a little to close but his Matrix with the same washer system shot up onto his window, over his car and sprayed mine hah.
champcaracing
Re: Front windsheild sprayer (Mavrik)
Post by champcaracing »
ah, silver...yes you can adjust those, need 1 needle and stick it in the nozzle, and MOVE SLOWLY, you'll see after you get the hang of it, how much alittle really is.
03 toyota matrix XRS 6 speed, lunar mist,factory 17 inch rims w/firehawks- summer tiresfactory 16 inch rims with dunlops- winter tirestrd sway bars, trd strut brace, trd sport muffler,trd quick shifter,trd cold air intake, toyota tundra dual horns,factory toyota wing from toyota canada, both front door handle modsNEW pioneer AVIC-D1 nav unit, XM radio installed
Re: Front windsheild sprayer (renik)
The '03-'04 models do have 3 jets per washer nozzle. The 2005 makes do with only one rectangular opening per nozzle.Perhaps, someone can check the '05 to see if it is any better/worse, if better, perhaps you could replace the nozzles.I would guess the 2005 nozzles make the washer fluid spray a smaller amount of fluid in a wider pattern.
Image Image
savedbyzero
Re: Front windsheild sprayer (ColonelPanic)
Post by savedbyzero »
How do yu guys notice this stuff! I feel I'm quite in tune with my car, but some of the info/trivia you guys know boggle my mind!
THIS IS WHAT I DO...http://www.studiothisis.com
Re: Front windsheild sprayer (savedbyzero)
lol... Let's just say, I had a couple of hours to compare the two remaining '04 Vibes on the lot with the two new '05 Vibes while the dealer was beating the heck out of my dash..
Image Image
savedbyzero
Ah yes! Boredom does reveal the strangrest things!
