245 k miles on engine
shibaman
Post by shibaman »
I was looking at a 89 Honda Prelude that has 245 k miles on it. It has had a valve job, water pump,thermostat,and cooling fan replaced. It sounds great but how long will the bottom end last or the auto trans? My concern it that it will be a $ pit will all the things that will break on a car with that milage on it. I need some feed back. Thanks.
Salsa basemoons and tunesInjen CAIHotchkis sway barsHotchkis springsCenterline RPM sMagnaflow muffler,stainless tipDevlop's custom STB
pa-vibe
Post by pa-vibe »
My buddy had an 89 accord and the transwent at 175000. the engine went at 200000, threw a rod i believe
Chad
shibaman
Re: 245 k miles on engine (joatmon)
Post by shibaman »
The timing belt was replaced when the valves were done. It is a Prelude Si with 4ws,air, auto, all power windows, sun roof. And of course red faded paint. It may clean up? The interior is clean. $1500 If it had 150 k I would buy right now! It was the top of the Prelude line.
millster
Re: 245 k miles on engine (shibaman)
Post by millster »
I think the parts I would worry about with that many miles are the tranny and the 4 wheel steering components. I don't believe I would pay that much for the car with that many miles on it personally.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
goodvibe
Re: 245 k miles on engine (silverawd26)
Post by goodvibe »
The problem is that you don't know how well it was mantained though you can assume he must of at least done a good job with those miles. The tranny has got to be about used up unless they're all highway miles. Compression check the motor. If it's not too bad than the motor might be good for a while. If not, you know that the oil has diluted with fuel through the rings since he's had a valve job. That compromises the oil protection and would be red flag. In reality, if the thing lasts close to a year without problems, it's still not a bad deal but any major fix makes one.
ebslopp
Re: 245 k miles on engine (goodvibe)
Post by ebslopp »
There are places that will sell you a rebuilt Japanese engine and install it for around $500 if it really is a concern. In Japan, it's required by law that you get a new engine after 100,000 miles. These used engines get rebuilt and sold in the US. There is nothing wrong with them, should be able to get another 100,000 miles with no problems. Just look for an import specialist near you.
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
