Amp and Subs
blk182@n7
Amp and Subs
Post by blk182@n7 »
Well i just did it...got an amp and subs. Coustics 601SE Stereo Power Amplifierbox & 2 CF1044 10" Carbon Fiber SubwooferSounds Perfect Installed for $500.00 a bit expensive but i wanted it to be seamless with the Stock Stereo. Will post pics i a min http://www.coustic.com/products/index.cfm
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
blk182@n7
Re: Amp and Subs (blk182@n7)
Post by blk182@n7 »
here is what it looks like
blk182@n7
Post by blk182@n7 »
here is a pic of the amp I had them install it so that the entire box and amp could be removed when i need it out.
blk182@n7
Post by blk182@n7 »
here is a cool pic of my baby
Pablo1669
Post by Pablo1669 »
Quote, originally posted by blk182@n7 »Installed for $500.00 a bit expensive but i wanted it to be seamless I'm guessing that 500 included the price of the subs and amp
-Brian
Jahntassa
Post by Jahntassa »
I'd say that's about right. Cost for a setup like that at Circuit City is pretty close.Install: $70Bazooka ELA3001 500 watt amp: $145Audiobahn AW1051T Dual VoiceCoil 300 Watt Sub: $90/per ($180 total)Dual 10" Box: $55Cables (Power/Audio): $90Total cost: $540And that's not including tax. Those particular Coustics don't look too bad, either, judging from the specs on their website. I'd say you got a good deal!http://www.coustic.com/product...4.cfm
blk182@n7
Post by blk182@n7 »
Price included everything and they installed it in 2 hours the same day.
Fialchar
Re: (blk182@n7)
Post by Fialchar »
That was a pretty good price, actually. I hope you like the system, let us know how it sounds (As a side note, you might want to make sure the amp isn't getting too hot between the box and the seats, sometimes they need a little air to breathe, but it shouldn't be a problem )
blk182@n7
Post by blk182@n7 »
I have about 5 in between the amp and the seatback, there is a contant flow of air to the rear so it doesn't get to hot, the system sounds perfect couldn't be happier, and it drowns out the traffic with out killing your ears.
