Horn (In Canada)
FoxTv
Horn (In Canada)
Post by FoxTv »
I read in other topic that you can change the stupid Vibe horn. So, there is a horn at Canadian Tire : Freeway Blaster Horns, 26.99 $CA. Do you think this horn is better that the one that come with the car ? I'm not a mecanic, so, I need something really easy to install.If it's not a geat horn, any one know a place in the Montreal (Quebec) region where I can buy great horns ?
Frosty
Re: Horn (FoxTv)
Post by Frosty »
I went to Canada Tire too! I think the freeway blaster is a 125 db horn. You know if you are not satisfied with the your horn you can bring it back to them!I went for the $20 (approx) Fiamm (I think that is what is was) low note 110 decibel horn and added it to the existing one. Now I have a normal sounding dual horn system. Everyone else says it is loud, but I think it sounds perfect to me With a dual horn rather than a replacement you have a spare for redundancy in case one horn fails you.It is an easy install electically, just one wire and a ground, make sure your new horn has a good ground either where you mount it or run a ground wire.It takes a bit of fiddling to mount the new horn behind the grill though, that is what took most of my 1.25 hours. Have fun!
Frosty 5 speed Vibe Power & Safety Packages. Naturally Aspirated my gallery
Stang2Vibe
Re: Horn (Frosty)
Post by Stang2Vibe »
You should have removed the grille. The left and right side come off separately and I think they are only held in place by a few screws and maybe a trim clip or two. I was already looking because I hate the sound of the puny little horn. When I get angry and lay on it in traffic, that whimpy litte beep just doesn't cut it. I would really like something more like a Mack dual air horn that really blasts and lets everyone know I'm pi--ed off so get the hell out of my way!
DopeVibeGT
Re: Horn (Stang2Vibe)
Post by DopeVibeGT »
LoL! I know what you're saying, Stang2Vibe. I laugh everytime I have to use the whimpy horn. :D
Pictures of my ride!!'03 Vibe GTMy AED GA!Work in progress
Cubanpete
Post by Cubanpete »
lol
Cubanpete
Re: Horn (Frosty)
Post by Cubanpete »
can the "freeway blaster" sub as a replacement or add-on? All you need is 1 wire.for add on and grab the ground of the car chasis, yes???
Frosty
Re: Horn (Cubanpete)
Post by Frosty »
quote:can the "freeway blaster" sub as a replacement or add-on? All you need is 1 wire.for add on and grab the ground of the car chasis, yes???Sure either or. The two horns run in parallel. The worst that can happen is you blow a fuse if both horns draw too much current. Just run one horn in that case.
