Aftermarket Subwoofer
grinder
Post by grinder »
I am looking for a suggestion for a good affordable aftermarket sub for my vibe. Does anyone have a suggestion.
Rick2003 FrostyMonotoneNavigation
russ257
Re: Aftermarket Subwoofer (grinder)
Post by russ257 »
whats your deffinition of affordable
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
Mike-NC
Post by Mike-NC »
I installed a Kenwood wOOx mini-sub. Cost from Crutchfield is $219. I ebayed mine for $190.Do a search for "wOOX" or look in the recent topics under the audio section for my install pics.Hope this helps! BTW, I am very pleased with it, but it is not for hardcore bass addicts.
2004 Salsa Two-Tone AWD M&T, Power Pkg., Factory 16" Alloys, cargo nets, cargo matMods: Kenwood wOOx mini-sub, front and rear mud flaps, 2 car seatsWeatherTech bug shieldWish List: Replacement Door speakers, Tint
Jahntassa
Post by Jahntassa »
I agree, what's affordable? You can get something like the w00x or a decent Bazooka tube for $200. If you want more than that, you'll probably be looking at least $300. Give us a price, and we'll give you some reccomendations!
rsgriff115
Post by rsgriff115 »
Um, i use two 12" MTX's (Thunder 6000's) and i like them very much, not too great on SQ -- partially my amps fault. One of these subs can be found for about 120 or less since they are last years model. They handle 250 watts RMS, so a good 2-Channel Amp bridged into one will provede best value, and then a box form your local retailer. Rockford Fostgates are also a good buy when it comes too subs. Also a loaded sub-box is not a bad value -- Infinity make one, Kenwood and there are of course the bass tubes, but have never heard one in an actual car. I recommend looking at crutchfileds website (www.crutchfield.com) and then find the parts cheaper. Just my opinions.
Nervous_Dog
Re: Aftermarket Subwoofer (rsgriff115)
Post by Nervous_Dog »
I bought my sub and amp at Sounddomain.com. I got a 12" sub in a Rockford poted box and a 200-watt amp w/wiring kit for about $250 shipped. I bought my sub as an open-box item (it was returned, but still had the factory warrenty). I saved about $60 on it and the only thing wrong with it was a small (nickle-sized) dirty spot on the front edge. You can't even see it when its in the car. I also bought last years model of the amp which saved another $30. It was the same specs as the current model, just the housing was slightly different.Just keep checking around and you can find some good deals.
Nervous Dog2003 Monotone Lava GT w/ M&T and PowerMods: 18" Bronze Tenzo-R Mean Six rims w/ Kumho MX12" Rockford Fosgate Punch Sub in slot ported box2 - Rockford Fosgate Punch 201S amps2 pair - Rockford Fosgate P162C in front/rear doorsSony Xplod 5710 head unitHidden Hitch
Fialchar
Re: Aftermarket Subwoofer (Nervous_Dog)
Post by Fialchar »
Are you looking for a sub to give better music quality (Fuller sound) or one to give hardcore bass? the wOOx is a mini powered sub that you would slide under a seat, and does sound good, but honestly is too expensive for what it does IMO. If you just want some basic bass then I'd go with a 12, for a high/punchy type of bass a pair of 10's would work, and for low rumbling bass, 15's are great. Let us know what you're looking for and how much you'd like to spend (Remember that you'll most likely need to buy an amp as well unless it's a powered sub).
