I have a question about the keyless entry Sys..
blk182@n7
Post by blk182@n7 »
On my GT I got a 3 buttom fob. the buttons are as follows lock unlock and hatch. The hatch button does nothing. Does anyone else have this issue? Should I take it in?
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
russ257
Re: I have a question about the keyless entry Sys.. (blk182@n7)
Post by russ257 »
common thing, you have to hold the button in for like 4 seconds. its ok i thought the same thing when i got mine
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
Sub-Vibe-R
Re: I have a question about the keyless entry Sys.. (russ257)
Post by Sub-Vibe-R »
Quote, originally posted by russ257 »common thing, you have to hold the button in for like 4 seconds. its ok i thought the same thing when i got mineRight, the harch takes 3 seconds to pop. If it does not, take it to the dealer, I've heard about some Vibe with the hatch selenoid not connected.
blk182@n7
Post by blk182@n7 »
kool i will check it out in a few min and post later . thanks again for the help.
rlong97150
Re: (blk182@n7)
Post by rlong97150 »
Is that something that is only with the 03's. I could swear my 04 pops immediately.ThanksBob
ragingfish
Re: (rlong97150)
Post by ragingfish »
Pretty sure the 04's function the same way.
2009 PONTIAC G8
PhiDelt
Post by PhiDelt »
I have an 04 and mine pops as soon as I hit the button
blk182@n7
Post by blk182@n7 »
it took 3 secs then pop...outstanding
SGT
Post by SGT »
I have a 2004 and tried this tonight. Window popped open immediately. No delay. I wonder if this changed from 2003 to 2004?
2004 Base Vibe - Frosty - Two Tone Automatic, ABS, 16 inch factory alloy wheels, Power Package, Cargo Nets and Mat
NovaResource2
Post by NovaResource2 »
Quote, originally posted by russ257 »common thing, you have to hold the button in for like 4 seconds. its ok i thought the same thing when i got mineThey should really put that information in the owners manual.
Jahntassa
Post by Jahntassa »
It's the same way with most keyfobs I think. My fiancee's 2000 Grand Am requires you to hold in the trunk button for a few seconds before it pops.
wicked1981
Re: (SGT)
Post by wicked1981 »
I have an 04 base auto and poped open as soon as touched the button.
03VibeGT6Spd
Post by 03VibeGT6Spd »
Maybe GM change it after so many people brought them in for service. lolI have to hold mine a few seconds, It took me a few minutes to figure that one out.
ragingfish
Re: (03VibeGT6Spd)
I remember messing with a vibe at the showroom when i was getting ready to buy, and being like "geez, off the lot this damn car is already broken!" then the dealer's like "no, you gotta hold it down slick." i was like. oops.
2009 PONTIAC G8
Jahntassa
Post by Jahntassa »
Better than my experience Mike, where the fobs weren't even programmed into the car! I asked the guy if it would go into a panic mode if you held down a button, and we realized neither of the remotes worked! 30 minutes later they had them programmed.
drunkenmaxx
Re: (Jahntassa)
Post by drunkenmaxx »
speaking of which, is there a panic mode?
Mr. Poopypants
Re: (Jahntassa)
Post by Mr. Poopypants »
Quote, originally posted by Jahntassa »Better than my experience Mike, where the fobs weren't even programmed into the car! I asked the guy if it would go into a panic mode if you held down a button, and we realized neither of the remotes worked! 30 minutes later they had them programmed.I had the same thing happen to mine.
Atomb
Post by Atomb »
the matrix fob will work with my 04 vibe???how do you program the right freq. for my lock system?
