TRD quickshifter
blk182@n7
TRD quickshifter
Post by blk182@n7 »
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
AKLGT
Re: TRD quickshifter (blk182@n7)
Post by AKLGT »
yes. it's been discussed a few times previously. only prob is that you have to cut into the center compartment under the shifter. if you do a search for quickshifter, you should find some of the threads that discuss how it works. i believe is reduces your shift throws by about 25%
AKLGT1998 Subaru 2.5RS
Devlop
Re: TRD quickshifter (trdvibe)
Post by Devlop »
TMW has one that should be out soon. As far as I know, you won't have to cut anything. It reduces the throw by 60% and shortens the shifter height by two inches. Here's a link:http://www.ptuning.com/html/se...=2003
blk182@n7
Post by blk182@n7 »
Hmmmm might be somthin to look into...
AKLGT
Re: (blk182@n7)
Post by AKLGT »
will be awhile down the road for me...
AKLGT
Re: (silverawd26)
Post by AKLGT »
ya, was thinking about brass bushings too. and they are supposed to be relatively inexpensive. and i will be waiting on a short/quick shifter...
blk182@n7
Post by blk182@n7 »
i was mostly ewanting to know if it was a noticable felling of a shorter shift and better fell then OEM. I know in my friends saleen the hurst shorty is much better them OEM.gives back the control to the driver much more fun to drive.......
Jahntassa
Post by Jahntassa »
Just signed up at ptuning to get an email when that TMW is available. Anything to get the shifting smoother on the GT is a good thing! As far as driving goes, that's my only complaint about the car, clunky shifting..Although I know this won't help with the clunk, it'll definitely make it more fun.
dmitri
Re: (Jahntassa)
Post by dmitri »
i have brass shifter bushings. world of difference, surprising how it is. im getting the TMW quickshifter the day it comes out...i need it
steletma
Re: (dmitri)
Post by steletma »
where can i get some brass bushings?
Psychobroker
Re: (steletma)
Post by Psychobroker »
Quote, originally posted by steletma »where can i get some brass bushings?RIGHT HERE
blk182@n7
Post by blk182@n7 »
just ordered mine today
