Matrix body kit that may fit the Vibe
blk182@n7
Post by blk182@n7 »
I found it here is a matrix body kit that you can order in seporate pieces. got to body kits| and then matrix | the evo set look smooth. http://grounddynamics.com/merchant/mainpage.htm
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
savedbyzero
Re: Matrix body kit that may fit the Vibe (blk182@n7)
Post by savedbyzero »
Yuck! Not my thing at all! It looks confused! Am I a rally car or caution light or a matrix?Would prolly take a fair bit of work to get it to fit. Is the rear bumper just a lip extension or does it replace the whole bumper? I feel like that would be the toughest part to deal with. The way the two attach is complete different on the sides where it meets the body. And nothing looks worse the an ill fitting bodykit...Be adventurous! Find a good body shop that does custom work and go for it!Just wouldn't be on my car.
THIS IS WHAT I DO...http://www.studiothisis.com
wicked1981
Post by wicked1981 »
Not bad something to look into. Custom body kit would be very expensive but would also be the only one alike.
blk182@n7
Post by blk182@n7 »
i got this today from those guys at http://www.grounddynamics.comDear Customer,The sides come in a pair. If you are interested give us a call. We dont have anything for the vibe yet, maybe a couple months.Thanks,Kevin Parkhttp://www.grounddynamics.com
blk182@n7
Post by blk182@n7 »
I evo set up 02-03 toyota matrix EVO-5 side skirts and rear bumper look way better than the GM set up. and the kit will work on the vibe as the matrix has the same rockers and lower rear fasca just the front on the matrix and the Vibe are completly different.
savedbyzero
Re: (blk182@n7)
so is the rear just a lip? if so, then you could probably get it to fit. but i'm pretty sure that the entire rear bumper is different between the two models. ours has part of the fender flare. the matrix doesn't.
AKLGT
Re: (savedbyzero)
Post by AKLGT »
the rear is an actual bumper replacement. and the vibe and trix are different. our rear lights are in the lower bumper while the trix lights are in the tail assemblies. you could prob still get that evo 5 kit and w/ some adjustment and conversion, make it work on the vibe probably pretty easy... much like fookyman did w/ the mazda 6 kit.but, would still be nice to have one that actually was made for the vibe in the first place. i want a FULL bumper replacement, not just a lip.
AKLGT1998 Subaru 2.5RS
blk182@n7
Post by blk182@n7 »
I see that it is a replacement rear. They say they are lookingto build a vibe kit in the next couple of months. i posted thir e-mail back to me.
DopeVibeGT
Post by DopeVibeGT »
I like the back and the sides. Front isnt too bad.
Pictures of my ride!!'03 Vibe GTMy AED GA!Work in progress
