FW Dyno's
blk182@n7
FW Dyno's
Post by blk182@n7 »
has anyone got some real numbers on the GT?
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
CaCathy13
Re: FW Dyno's (blk182@n7)
Post by CaCathy13 »
CathyWhen this baby hits 6.000rpm's, you're gonna see some serious sh*t-Got Lift?'03 Neptune Vibe GT: SLP Hood, AEM CAI, Thermal R&D exhaust, Unorthodox underdrive pullies, K&N filter, G-Racing 17' Mito's, TEIN Springs, yellow calipers, GrafxWerks, Silverstar's, XM, Infinity basslink-more mods to come!http://www.mitro.net/vibe
blk182@n7
Post by blk182@n7 »
it looks good, there just has to be a way to get more Lb FT out of this engine.
AKLGT
Re: (blk182@n7)
Post by AKLGT »
here's the link larry posted from MO that has the dyno results for an XRS w/ TRD CAI, exhaust, and unichip. I have the TRD CAI and unichip, hopefully getting an exhaust by next spring. http://www.matrixowners.com/mo...art=0
AKLGT1998 Subaru 2.5RS
GT-X
Re: (trdvibe)
Post by GT-X »
check out Monkey Wrench they got 23 ft-lb at the wheels with an Apex-i ecu Piggy back I think check out there web page http://www.monkeywrenchracing.com
Injen CAIGReddy ExhaustProgress 2.2 drop SpringsRollers: Enkei RS7 Rubber: Nitto 555 225/40R18Red Windshield StripDeVlop Strut Tower Braceand Mad Style!!!
GT-X
Re: (GT-X)
Post by GT-X »
goodvibe
Re: (GT-X)
Post by goodvibe »
That's not a piggyback. It replaces the entire ECU and doesn't have cold start, knock sensors or safety modes etc. Great for racers but not the best for a daily driver. Unichip is still the only piggyback that works for a 2zz.
blk182@n7
Post by blk182@n7 »
I am talking with jet to see if there is one in the works but i doubt it.
goodvibe
Re: (blk182@n7)
Post by goodvibe »
Jet will be happy to sell you something. Less so to give you a refund when it doesn't work. This motor has been around for over 5 years and Jet as well as others have not had success with the 2zz. Only Unichip has a remap that lasts. I know it's expensive but it is priced right for the hardware you get, they are premaped and remaps are cheap.
