Boost gauge
Supercharger, turbo, nitrous, and anything that has to do with forced induction
teammonkeys
Boost gauge
Post by teammonkeys »
this is a question for ones with boost gauge. How did you get the vacuum line from under the hood to the cabin? Did you drill a new whole?I haven't installed the gauge yet because of this.However, I did install it for a brief moment to see what are the readings...Idle -20 psi... I think is a vacuum.slow acceleration, needles moves to the positive.hard acceleration to near redline, roughly around 7. I will make a digital video and post it.I didnot use the T-connector. I just simple removed the brass hex screew and replace it with a brass fitting with a vacuum connector that came with the Boost Gauge.
2003 AWD Vibe.Satellite Silver, monotone.Fully Loaded with Machine gun mounted on top accessible via Moon Roof. Just Kidding, i have no gun but I do have a sun/moon roof.Side Airbag with shooting 6 disc changer.ilquikgtx's supercharger installed.
Devlop
Re: Boost gauge (teammonkeys)
Post by Devlop »
There is a wiring harness that runs thru the firewall on the drivers side. You can punch a hole in the rubber gromet and run the line thru that.
greenfire
Post by greenfire »
Those numbers sound about right. I think my idle is -18. Your boost should be around 7.5... looks good! I think my vacuum line is going thru that grommet. Thats cool your boost gauge came with a special connector. Hows it running on the road? Hows the power?
2005 Flint Mica Scion tCTRD exhaustFormer Car: 2003 Matrix xr4wd
teammonkeys
Re: Boost gauge (greenfire)
The power is great... I clocked myself from 0-60 mph using grade school football rushing method... you know.. one-one-thousand, two-one-thousand and so on...I got up to eight-one-thousand.I don't have the boost installed... I just it used to monitor the boost while the car was parked.
teammonkeys
OK.. I installed it but the dam vacuum hose is short... Well, it long enough if i can go directly from the firewall to the driver's pillar but i cannot get the vacuum hose thru the dash to the crack between the dash and the pillar. So currently, the gauge is in the little pull out tray on the left of the steering wheel.
Faultline
Post by Faultline »
I put my boost guage in the A/c vent...the left center one...it still lets the air thru...I like it! ..I came real close to putting the guage in the center of a small stuffed bear , and sitting it one the dash by the pillar....At work they call me "turbo bear"....so I bought some teddybears...and....it just did not work for me in the end..Btw, I used a coat hanger to push the vacuum line to the guage thru the fire wall where the wires go thru.... whatever it takes!
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
dsegundo
Post by dsegundo »
Where do you get one of these? Is it hard to install?
teammonkeys
Re: (dsegundo)
I got mine at peps boy for 19.99.... I have pictures.. I will post it later. I love they way how my girlfriend installed the pod into the pillar using puddie.
chargedvibe
Re: (teammonkeys)
Post by chargedvibe »
When they installed my supercharger, the instuructions told them to pull the wires through the wire harness on the pass. side behined the glove box.
teammonkeys
Re: (chargedvibe)
yeah.. that is for the supercharger wires... You can also put the vacuum wires thru there too but you boost gauge will be limited to the lenght of your vacuum line if you don't get a linker.
tbm34
Post by tbm34 »
Quote, originally posted by teammonkeys »I didnot use the T-connector. I just simple removed the brass hex screew and replace it with a brass fitting with a vacuum connector that came with the Boost Gauge.This sounds like how bellwilliam installed his. Where is the brass hex screw located?
Base Shadow monotone 5-spd, Moons & Tunes, Power Package & ABS. Alloy wheels, Progress RSB, Silverstars. TRD supercharger w/ custom tuned Unichip, and magnaflow true cat-back exhaust.
bellwilliam
Re: Boost gauge (tbm34)
Post by bellwilliam »
Quote, originally posted by tbm34 »This sounds like how bellwilliam installed his. Where is the brass hex screw located?if you are standing in the front of the car looking at the supercharger, it is on the right hand side and near the top of the supercharger, you can't missed it. I got my boost guage at Pep Boys for $15 !! Autozone wants $59 for theirs.
Bellwilliam2003 S/C VibeTrim : Base, Abyss , AutoOptions: Moon & Tunes, Power Upgrades: Supercharger, Split Second A/F controller, 225/45-17, My other cars are PTE Miata, 13 Tesla S, 13 Volt, 06 997
