gearbox whine?
ChuckP
gearbox whine?
Post by ChuckP »
Does anybody else experience this? I only hear it when in 4-6 gear. When I let off the gas it quiets down, on the gas gets louder. I know we don't have alot of insulation in these cars, but it seems quite loud. I was just wondering if this might be normal or if I should have it checked out.( don't want to sit at dealer for who knows how long to be told its normal)
2003 Vibe GT Neptune(blue), TRD exhaust, TRD air filter
d_m_kolb
Re: gearbox whine? (ChuckP)
Post by d_m_kolb »
I'd check the fluid level of the trany. If it low then fill it up and make sure it's not leaking from somewhere. If it normal then you should probably see a dealer.
ChuckP
Re: gearbox whine? (Admin II)
Post by ChuckP »
Had it checked out today, was told there was too much fluid( almost 1 quart!) They put correct level in and took it on a test ride, problem seems to be fixed. Got no explanation on why there was too much fluid in it, my guess is the little robot got carried away.
d_m_kolb
Post by d_m_kolb »
I should have said maybe to much fluid, but I figured more on it being low. Oh well glad you got it fixed.
