I just lowered my Vibe on Tuesday. I used Skunk2 coil overs. The rear setup sucks on this kit. The top spring purch that keeps the coils centered on the upper mount is a rubber top hat shaped boot. I guess they wanted it to also act as a bump stop because if lowered more than 3 inches the rear shock body rides on it giving a harsh bouncy ride. Even raising it up about 1/2 an inch it still hits on a hard bump. I'm going to make a new upper perch for the Spring to set on that will allow the shock to travel fully up into the mount and cut down the stock bump stops and place them back on the shock. Hopfully this will improve the ride at the hight adjustment I've got it set at. Has anyone installed the Skunk2 coilovers and incountered this problem with the rear??? If my new purch works I'll post dimentions and parts used to make it. It will require some welding.
