Quote »found this pic, if you're going to bake your headlights, be sure to set the oven to bake and not to broil
http://justin.strzelecki.ca/Images/headlight3.jpg Holy crap! That guy must have a) left his oven on (you just preheat it to 300F, then turn it off - direct flames = bad) or b) didn't use rags on the racks to absorb some of the remaining heat.As far as what it would cost, these headlight housings list for up to $300 USD each from the dealer. I'm sure they're a lot cheaper from gmpartsdirect.com, but I'd just try to buy another couple off eBay first (wrecked vibes stripped for parts). $200-$300 is way too much.I'll let you know if I find anything, Joe. Alternatively, keep a lookout yourself and let me know. I don't know what I'd charge at this point, but I'd factor in materials expense and a bit more for time spent.EDIT: Found a couple already...only two though, and one has a repaired mounting tab:RH (driver's side) =
http://cgi.ebay.com/ebaymotors...=WDVW - this one's good, nothing broken according to the sellerLH (psgr side) =
http://cgi.ebay.com/ebaymotors...=WDVW - broken mounting tab, JUST like one of the ones I bought. After putting it in the oven, the repaired tab fell off, but I think that's because the other guy used super glue. I don't want to send you two modd'd housings with one busted tab. Alternatively, I could just send you the inner painted housing, but then you'd still need to remove yours and pop them in the oven, re-seal, etc. it does get tricky.
