ECU..Where?
rcasciola
ECU..Where?
Post by rcasciola »
does anyone know where the ecu is located on the base vibe?
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
AKLGT
Re: ECU..Where? (rcasciola)
Post by AKLGT »
the ecu is located under the glove box. you have to remove the glove box and a couple screws to get to it.
AKLGT1998 Subaru 2.5RS
rcasciola
Re: ECU..Where? (trdvibe)
Post by rcasciola »
i was reading in a magazine...that after you do some engine mods, its probably a good idea to remove the ecu for an hour or so to let it reset..it could give some hrspwr gains....any thoughts?
ragingfish
Post by ragingfish »
Just disconnect the battery. No need to remove the entire ECU.
2009 PONTIAC G8
rcasciola
Re: ECU..Where? (ragingfish)
Post by rcasciola »
ha...how long would it take to reset?
rcasciola
Re: ECU..Where? (silverawd26)
Post by rcasciola »
so...would it give it a horsepower difference????
rcasciola
Post by rcasciola »
awesome... i think ill do that first thig in the norning:)
GT_03
Post by GT_03 »
See, when i was modded my truck i got instructions to reset the ECU by disconnecting the Neg terminal and turning the key back for 15 seconds. It seemed to work in my truck, not sure if it applies here, just a thought.
Not a Vibe owner anymore
AKLGT
Re: ECU..Where? (GT_03)
Post by AKLGT »
when doing engine mods of any kind, you should ALWAYS disconnect the negative battery terminal!
