Here is the last time I will post anything about ground wires, and I don't care if it does or does not add hp. all I want to know if:1. Has any one installed them on a GT?2. Were did you mount them?3. Where did you get the 10mm bolt? The GT seems to have a ground to the chasis to the batt to the trany to the engine to the other side of the chasis........
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
umm..... saved by zero just posted this a few days ago. he's got a 2zz. i would im him and ask all your questions since he's the one that did this. http://forums.genvibe.com/zerothread?id=5902
