Need some more info. Do you already have the Vibe? Are you ordering one?You can get a PIE adapter that'll add an Aux-in to the nav system, and connect most any of the XM units (SkiFi, Roady, Commander), but nothing will directly connect and control through the Nav system unless it's factory installed.
I have a piece from PIE called the X3, part X3-GM12. I think it was around $80 when I bought it. Plugs in behind the radio between the radio and the CD changer and adds 3 aux inputs. I have XM, Sirius, and my MP3 player connected to mine.I got mine from the xmfanstore which is now pretty much defunct. I think you can do a google search on PIE x3 and get a bunch of results.
http://forums.genvibe.com/zerothread?id=910&page=4 i posted some info on this thread that will help you.... its basically the same thing jagntassa is talking about.... but for anyone else that doesn't have a factory nav. sys or cd changer this will help them cause this part doesn't require the slave unit
WHEN I SAY "STOMP"....YOU SAY "WOOP WOOP""STOMP"mmfcl
Quote, originally posted by faygolovinjuggalo »http://forums.genvibe.com/zerothread?id=910&page=4 i posted some info on this thread that will help you.... its basically the same thing jagntassa is talking about.... but for anyone else that doesn't have a factory nav. sys or cd changer this will help them cause this part doesn't require the slave unitdon't jump the gun there, we still don't know that part will work.
have some faith.... i do.... or i wouldn't have ordered it.... they are hard to come across still though....they would only send vance 2 of them... and they haven't got here yet....
Quote, originally posted by russ257 »xm and sirius isnt that overkill?If you're gonna do it, overdo it!I've been a fan of Satellite radio since it came out. XM was first, and I recently got Sirius. It isn't really overkill because what they play on the channels is completely different. What I listen to depends on my mood at the time.The Sirius units have a stronger audio output than the XM as well, so it works better with my setup..
Quote, originally posted by Jahntassa »I have a piece from PIE called the X3, part X3-GM12. I think it was around $80 when I bought it. Plugs in behind the radio between the radio and the CD changer and adds 3 aux inputs. I have XM, Sirius, and my MP3 player connected to mine.WE NEED PICTURES!!
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
Suresure..i'll see what I can get. The PIE unit is shoved behind the glove compartment (wedged, rather).
