Ruptured Fuel Line
dmitri
Ruptured Fuel Line
Post by dmitri »
Yup. I dunno how i did it, but its a brittle plastic and easy to crack so to anyone doing engine work, be careful with it. It goes into the fuel rail, and is about a foot long...that is the section i cracked. A foot or so later theres a plug where it turns hard again I spilled alot of gass everywhere, and i didnt know what it was for a day, i just smelled gas really heavily. my car could have caught on fire! it was so close to the headers! im very lucky.anyone know if they make stainless steel braided lines for our engine?
dmitri
Re: Ruptured Fuel Line (silverawd26)
Post by dmitri »
its $78 so no one knows anything bout aftermarket lines or fuel rail?
satur9
Post by satur9 »
fuel line is not vehicle specific. youll have to buy a 12"in or lonnger piece. andget the fittings to adapt it.thats what stafford did. he might be able to tell you what specific fitting for it.if the guy at the auto parts store isnt a dork he should be able to look at it and tell.
AKLGT
Re: Ruptured Fuel Line (satur9)
Post by AKLGT »
found this on ebay, dmitri. don't know if this is what you're talking about or not... http://cgi.ebay.com/ebaymotors...29849
AKLGT1998 Subaru 2.5RS
dmitri
Re: Ruptured Fuel Line (trdvibe)
Post by dmitri »
Would that fuel rail work? im thinking of somehow taking that and enlarging the passages and putting on new injectors. anyone know?
cohocarl
Re: Ruptured Fuel Line (dmitri)
Post by cohocarl »
Quote, originally posted by dmitri »enlarging the passages and putting on new injectors. anyone know?Can I ask why you would want to go to all the trouble doing that? Thinking of adding a turbo or blower where you'd need more fuel?Just curious what you had in mind.
satur9
Post by satur9 »
if by enlarging the passages you mean the center bore. you cant do that on a stock hollow rail.aftermarket billet rails are usaully larger anyway.you can put larger injectors in the stock rail. it should flow enough for well over 300hp. any injector larger than stock requires fuel management.afc, emanage, unichip,split second. stafford makes a nice billet rail with connectors for sale check out http://www.newcelica.com for info.
dmitri
Post by dmitri »
i dunno if imma turbo im probly gonna go with unichip or something....but right now i cant get into second gear when racing without major grinding
