MOMO Shift boot install
Bocaj77
Post by Bocaj77 »
First I removed the stock boot. After removing the boot I cut the stock boot down to the base. There is a foam base cut down to that. The I went to the local craft store and got a needle and some thread. Get the biggest needle & thread you can get. The I sowed the Momo boot the the base of the stock boot. You need the base of the stock boot so it will clip into the center cluster. After sowing it all the way around reinstall the boot. It was actually pretty easy to do. The only thing I messed up on is I should have got the smaller Momo boot. Check out the pict.
