Injen CAI Modified
Bocaj77
Injen CAI Modified
Post by Bocaj77 »
If anyone has had a problem with the Injen Intake fitting on the Vibe because of the Fog light getting in the way I found that if you cut off about 2" of the tube it fits perfectly on the Vibe.
rasermon
Re: Injen CAI Modified (Bocaj77)
Post by rasermon »
It has been talked about, but I think your the first to trim some off. Post a pic and show us.
Kissfan79
Post by Kissfan79 »
I had often wondered if that was a solution to that problem after hearing everyone talk about how close the filter comes to the fog lights. Evidently, it works . Wow...that would suck to cut off 2" of your CAI and find out it didn't solve anything or worse.....create a new problem.Jim
Abyss Vibe GT monotoneMoon & Tunes w/6 disc changerCargo nets and mat93 Octane w/ lots o' KISS in the CD changer
wicked1981
Re: Injen CAI Modified (Kissfan79)
Post by wicked1981 »
I had this problem and the solution from someone here was just push the filter farther up the tube. It worked.... No trimming needed.
2006 Pontiac G6 GTP3.9L V-6 240hp and 241 lb-ft or torque18" Aluminum, five-spoke, flangeless200 Watt, 8 speaker Monsoon sysChrome dual exhaust tipsLiquid Silver MetallicBorla Custom ExhaustDr. Speed Cold Air Intake
ragingfish
Post by ragingfish »
I remember reading that altering or cutting the intake affects how well it works...and can cause power losses.
2009 PONTIAC G8
redlava
Re: (ragingfish)
Post by redlava »
Probably won't affect it if you cut off 2 inches. Probably just a warning to people who cut it off and make it a shortram. I know a few people in here have done that, hopefully with no side effects. I had a little problem with mine fitting, a little crooked, but with a little negotiating it went on.
Bocaj77
Re: Injen CAI Modified (wicked1981)
Post by Bocaj77 »
If you push the tube up inside the filter it causes turbulance and dosen't let the air flow smoothly.
