Opinions of one versus another? Are the Sportlines too low to go with stock shocks/struts? What about camber adjustment - are the Sportlines too low to align the vehicle correctly? I'd be interested to hear from folks that have springs installed already - how is it to live with them on a daily basis?Thanks!
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
'03 Vibe GT monotone silver/black interior, 17 inch wheels, 6-disc changer, power packageMods: AEM intake, TRD springs, A-spec Strut Bar'01 Corvette Coupe silver/black interior, six-speed, Z51, a few mods, 12.29 at 117.3mph in 1/4 mile on street tires.
Heres a pic of our Matrix we did.... http://www.hotchkistuning.com/frames/02 ... matrix.htm The Hotchkis coils will lower the car 1.5" (38mm) in front with a spring rate of 180 lbs/in and 1 1/8" (29mm) in the rear with a spring rate of 350 lbs/in... Both coils are linear / straight rate... Meaning, that over time they won't sag or go lower than when you first got them installed like most progressive coils do....
"Don't settle for less, cause that's what you'll get"
I ended up going with the sportlines... 2" drop. My lower control arm is just about parallel to the ground, so any lower would be bad for handling... the drop is nice, the car handles well, but when I put these on (last April) there weren't any aftermarket dampers out yet for our cars. With the stock dampers the car bounces a little when you have ripples in the pavement (maybe 5% of the time). Other than that, I'm very satisfied with the springs, the Vibe sits more like a car now, less like a mini SUV... Pete
Psychobroker, Hotchkis are variable rate both front and rear but firmer than Pro-Kits. Pro-Kits/TRD match the stock shocks best and are fixed rate in the rear, variable in front. H&R also uses this setup for front drives to counteract understeer and squat during acceleration. Pro-Kits/TRD or Hotchkis seem to be the best if you want to have good wheel travel and handling without going to coil overs or cutting your bump stops and sacrificing the shocks. I've got the TRDs and love them. Make sure you get the progress rear bar regardless of springs.
Quote, originally posted by goodvibe »Pro-Kits/TRD or Hotchkis seem to be the best if you want to have good wheel travel and handling without going to coil overs or cutting your bump stops and sacrificing the shocks. I thought that the Hotchkis springs provided new bumpstops, which is the same as cutting your old ones? Also, are you saying that cutting your bump stops will sacrifice your shocks life, or just their quality? Just curious, because I don't see how shortening the stroke will cause any damage.
It's all comprimize. If you cut the bumpstops your more likely to bottom the shock and have a failure. You can always not cut them to protect the shock at the expence of wheel travel. I suspect the Hotchkis bumpstops are less compliant to protect the shocks better if they hit though I doubt they touch them very often.
